Two PIC 18f4620, 1 as master & 2nd is slave I2C problem
ubuntuman
PostPosted: Wed Nov 15, 2017 5:54 am     Reply with quote
The complete Master code. HS oscillator mode 4MHz.
const long int crystalOscillator =4000000;
unsigned short int temp=0;
void I2C_Master_Init(const unsigned long int c)
 SSPCON1 = 0b00101000;
 SSPCON2 = 0;
 SSPADD = (crystalOscillator/(4*c))-1;
 SSPSTAT = 0b11000000;
 TRISC.B3 = 1; //Setting as input as given in datasheet
 TRISC.B4 = 1; //Setting as input as given in datasheet
void I2C_Master_Wait()
 while ((SSPSTAT & 0x04) || (SSPCON2 & 0x1F));
void I2C_Master_Start()
 I2C_Master_Wait();
 SSPCON2.SEN = 1;
void I2C_Master_RepeatedStart()
 I2C_Master_Wait();
 SSPCON2.RSEN = 1;
void I2C_Master_Stop()
 I2C_Master_Wait();
 SSPCON2.PEN = 1;
void I2C_Master_Write(unsigned short int d)
 I2C_Master_Wait();
 SSPBUF = d;
unsigned short int I2C_Master_Read(unsigned short int a)
 unsigned short int temp;
 I2C_Master_Wait();
 SSPCON2.RCEN = 1;
 I2C_Master_Wait();
 temp = SSPBUF;
 I2C_Master_Wait();
 if(a==1){SSPCON2.ACKDT=1;}
 else{SSPCON2.ACKDT=0;}
 SSPCON2.ACKEN = 1;
 return temp;
 I2C_Master_Init(100000); //Initialize I2C Master with 100KHz clock
 //I2C1_Init(50000);
 OSCTUNE.PLLEN=0;
 Delay_ms(500);
 TRISB=0;
 PORTB=0;
 I2C_Master_Start();
 I2C_Master_Write(0xAA); //Write data
 //I2C_Master_Write(0x00);
 I2C_Master_Stop();
 Delay_ms(5000);
The complete Slave code . HS oscillator mode .4MHZ
unsigned short int  zed=0;
volatile unsigned short int  new =0 ,dataRead=0 , dataWrite=0;
unsigned char dataReadCh[7] , dataWriteCh[7];
void interrupt()
 if(PIR1.SSPIF == 1)
  SSPCON1.CKP = 0;
  new=1;
  zed = SSPBUF;
  PIR1.SSPIF = 0;
  SSPCON1.CKP = 1;
  if ((SSPCON1.SSPOV) || (SSPCON1.WCOL))
   zed = SSPBUF; // Read the previous value to clear the buffer
   SSPCON1.SSPOV = 0; // Clear the overflow flag
   SSPCON1.WCOL = 0; // Clear the collision bit
   SSPCON1.CKP = 1;
  if(!SSPSTAT.D_A && !SSPSTAT.R_W)
   while(!SSPSTAT.BF){};
   while(SSPSTAT.BF){dataRead = SSPBUF;}
   SSPCON1.CKP = 1;
  else if(SSPSTAT.D_A && SSPSTAT.R_W)
   while(SSPSTAT.BF){zed = SSPBUF;}
   SSPBUF = dataWrite ;
   SSPCON1.CKP = 1;
   while(SSPSTAT.BF){};
  PIR1.SSPIF = 0;
void I2C_Slave_Init(unsigned short int address)
 SSPADD = address;
 SSPCON1 = 0b00110110;
 SSPCON2 = 0b00000001;
 //TRISC.B3 = 1; //Setting as input as given in datasheet
 //TRISC.B4 = 1; //Setting as input as given in datasheet
 TRISC=0b00011000;
 LATC= 0b00011000;
 INTCON = 0b00000000;
 INTCON.PEIE = 1;
 INTCON.GIE = 1;
 PIE1.SSPIE = 1;
 PIR1.SSPIF = 0;
 while(SSPSTAT.BF){zed = SSPBUF;SSPCON1.SSPOV = 0;SSPCON1.WCOL = 0;}
  OSCTUNE.PLLEN=0;
  ADCON1=0b00001111;
  TRISA.B0 = 0; //PORTD as output
  PORTA.B0=0;
  I2C_Slave_Init(0xAA); //Initialize as a I2C Slave with address 0x30
   if(new==1)
      PORTA.B0=1;
      new=0;
The problem is each time I send 0xAA from the master to the slave after putting 0xAA to slave SSPADD, I get NOTACK signal. I don't know where is the thing who doesn't work.
Here you are, screenShot for the WaveForm i get https://imgur.com/2VGF4Gk
PostPosted: Wed Nov 15, 2017 6:34 am     Reply with quote
quick comments
1. Doesn't look like CCS C code. CCS supply easy to use I2C functions
2. No PIC device header as 1st line of code, can't cut/paste, no fuses?
3. With ANY I2C program, run I2C Scanner program from code library
PostPosted: Wed Nov 15, 2017 6:43 am     Reply with quote
It's for the MikroC compiler. Not CCS.
ubuntuman
PostPosted: Wed Nov 15, 2017 7:21 am     Reply with quote
Right but the problem is not in compilers. It is in the pic 18f4620 settings and in the MSSP hardware register settings so if you have any working code for 18f4620 master/slave written in any language, pass it pls to me.
PostPosted: Wed Nov 15, 2017 7:45 am     Reply with quote
We won't have anything you can use. CCS has built-in functions to do
all the i2c setup and bus transactions. We don't have to write to PIC
registers to make something work.
For example, you've got this as your setup code in MikroC:
 SSPCON2 = 0;
We would write something like:
#use i2c(Master, I2C1)
and that would handle all the setup.
Another example. This is how you do a start in MikroC.
 I2C_Master_Wait();
 SSPCON2.SEN = 1;
This is how we do it in CCS.
i2c_start();
See, our way of coding won't help you. You need to go to a MikroC forum.
PostPosted: Wed Nov 15, 2017 8:55 am     Reply with quote
re:
It'd be better to just buy the CCS compiler !! Razz
His project could be up and running in an hour or so....
AND
then we could help him...
