Empty field with strok
cvargcal
PostPosted: Mon Oct 23, 2017 10:03 pm     Reply with quote
I am trying to tokenize a string but I need to know exactly when no data is seen between two tokens. e.g when tokenizing the following string "a,b,c,,,d,e" I need to know about the two empty slots between 'd' and 'e'... which I am unable to find out simply using strtok().
I want write "0" if is empty
  char str[150];
   char gprmc[] = "$GPRMC,";
   char tokens[] = ",";
   int i;
   char *p, *lat=0, *latDir=0, *lon=0, *lonDir=0, *time=0,*validity=0,*speed=0,*course=0,*date=0,*variation=0,*east=0,*checksum;
   fgets(str, STREAM_GPS);  ///fprintf(STREAM_USB,"%s\r\n",str);
      if (find_string(str,gprmc)){         //if (strstr(str, gprmc) != 0){
         fprintf(STREAM_USB, "%s", str);
         p = strtok(str, tokens);
         i = 0;
         while(p != NULL){
            switch(i++){
             // !$GPRMC,045103.000,A,3014.1984,N,09749.2872,W,0.67,161.46,030913,,,A*7C
               case 1:  time = p;       break;      //  1   220516     Time Stamp
               case 2:  validity=p;     break;      //  2   A          validity - A-ok, V-invalid
               case 3:  lat = p;        break;      //  3   5133.82    current Latitude
               case 4:  latDir = p;     break;      //  4   N          North/South
               case 5:  lon = p;        break;      //  5   00042.24   current Longitude
               case 6:  lonDir = p;     break;      //  6   W          East/West
               case 7:  speed = p;      break;      //  7   173.8      Speed in knots
               case 8:  course = p;     break;      //  8   231.8      True course
               case 9:  date = p;       break;      //  9   130694     Date Stamp
               case 10: variation = p;  break;      //  10  004.2      Variation
               case 11: east = p;       break;      //  11  W          East/West
               case 12: checksum = p;   break;      //  12  *70        checksum
               default: break;
            p = strtok(NULL, tokens);
for example: $GPRMC,040146.000,A,,,,W,,,241017,,,A*44
How I can put "0" if the data is empty?
I want similar to
https://stackoverflow.com/questions/8705844/need-to-know-when-no-data-appears-between-two-token-separators-using-strtok
PostPosted: Tue Oct 24, 2017 12:47 am     Reply with quote
It tells you the answer in those threads:
Use strsep() instead of strtok(). See the link below for strsep() source:
https://code.woboq.org/userspace/glibc/string/strsep.c.html
When translating that code, remember that 'const' in normal C is
different from 'const' in CCS.
cvargcal
PostPosted: Tue Oct 24, 2017 8:08 am     Reply with quote
Hi, Thanks so much for you answer,
I tried translating but not work
Original
char *strtok_single (char * str, char const * delims)
  static char  * src = NULL;
  char  *  p,  * ret = 0;
  if (str != NULL)
    src = str;
  if (src == NULL)
    return NULL;
  if ((p = strpbrk (src, delims)) != NULL) {
    *p  = 0;
    ret = src;
    src = ++p;
  } else if (*src) {
    ret = src;
    src = NULL;
  return ret;
example
  char delims[] = ",";
  char data  [] = "foo,bar,,baz,biz";
  char * p    = strtok_single (data, delims);
  while (p) {
    printf ("%s\n", *p ? p : "<empty>");
    p = strtok_single (NULL, delims);
output
foo
bar
<empty>
baz
biz
To CCS
void main(void){
 while(true){
  char data[] = "foo,bar,,baz,biz";
  char *p;
  p= strtok_single (data, delims);
  while (p) {
  fprintf(STREAM_USB, "%s\n", *p ? p : "<empty>");
char *strtok_single (char *str, char  *delims){
  static char  *src = NULL;
  char  *p,  *ret = 0;
  if (str != NULL)    src = str;
  if (src == NULL)    return NULL;
  if (p != NULL) {
    *p  = 0;
    ret = src;
    src = ++p;
  else {
  if(*src){
    ret = src;
    src = NULL;
  return ret;
No work as show the example... work as do it normally
Crying or Very sad
PostPosted: Tue Oct 24, 2017 1:40 pm     Reply with quote
Have you got PASS_STRINGS=IN_RAM
This is needed or the "<EMPTY>" won't code as a pointer.
I'd explicitly test for the NULL, rather than relying on this coding as FALSE
(*p!=NULL)?p:"<ENTER>"
cvargcal
PostPosted: Tue Oct 24, 2017 3:44 pm     Reply with quote
mmm I dont undertand if i see NULL value in debug by proteus... and that line has not effect
fprintf(STREAM_USB, "%s\n", (p!=NULL)?p:"<ENTER>");
Evil or Very Mad Evil or Very Mad
guy
PostPosted: Wed Oct 25, 2017 7:12 am     Reply with quote
See the sticky at the top of the forum. Proteus simulator is not welcome here since it is not a good simulator. Can you set up a real PIC and debugger?
PostPosted: Wed Oct 25, 2017 7:25 am     Reply with quote
yeah Proteus is so full of it's own bugs, I'm NOT surprised it doesn't work as expected...
I supose the FIRST question we have to ask when replying to every (well most) posts is...
Is this REAL hardware or a 'simulation' ?
PostPosted: Wed Oct 25, 2017 9:02 am     Reply with quote
Post the results that you get from the translated code.
You said the good code produces this:
foo
bar
<empty>
baz
biz
Post what the bad code produces.
cvargcal
PostPosted: Wed Oct 25, 2017 4:29 pm     Reply with quote
foo
bar
<empty>
baz
biz
Yes, proteus not too good...
the result is:
bar
baz
biz
No put <empty> , so the code do it the same as do it my code....
mmmm
I read the function strsep() is better, so how i can use this:
    char *strsep (char **stringp,  char *delim){
     char *begin, *end;
    begin = *stringp;
    if (begin == NULL)
      return NULL;
    /* Find the end of the token.  */
     end = begin + strcspn (begin, delim);
    if (*end)       {
        /* Terminate the token and set *STRINGP past NUL character.  */
        *end++ = '\0';
        *stringp = end;
    else{
       /* No more delimiters; this is the last token.  */
       *stringp = NULL;
     return begin;
