rfjhh
SPI comm |
Posted: Thu Jun 15, 2017 9:05 am |
I'm new in SPI comms. I need to communicate two PICs:
16F887 Master
16F886 Slave
I've written the following two programs:
MASTER:
Code: | #include<16f887.h>
#use delay (clock = 20 MHz)
#include<LCD.c>
#fuses HS, NOWDT, NOMCLR, NOBROWNOUT, NOLVP, NOPROTECT, NOFCMEN, NODEBUG
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
int8 valor;
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
lcd_gotoxy(1,1);
printf(lcd_putc, "SPI maestro");
while(true)
output_bit(PIN_B0, 1); // SS
lcd_gotoxy(1,2);
printf(lcd_putc, "Recibiendo");
valor=spi_read();
delay_ms(2);
lcd_gotoxy(1,2);
printf(lcd_putc, "Valor = %u", valor);
output_bit(PIN_B0, 0);
SLAVE
#include<16f886.h>
#use delay (clock = 8 MHz)
#include<LCD.c>
#fuses INTRC_IO, NOWDT, NOMCLR, NOBROWNOUT, NOLVP, NOPROTECT, NOFCMEN, NODEBUG
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
/* RC3 SPI CLK
RC4 SPI SDI
RC5 SPI SDO
RC0 SPI SS
int8 valor;
setup_spi(SPI_SLAVE | SPI_H_TO_L);
lcd_gotoxy(1,1);
printf(lcd_putc, "SPI esclavo");
setup_oscillator(OSC_8MHZ);
while(true)
if(input(PIN_C0)==1) // entrada SS
lcd_gotoxy(1,2);
printf(lcd_putc, "Enviando");
spi_write(input_b());
lcd_gotoxy(1,2);
printf(lcd_putc, "Terminado");
But I have nothing in SCK, SDO, SDI.
May somebody help me?
Regards
Ricardo |
alan
Joined: 12 Nov 2012 Posts: 349 Location: South Africa
Posted: Thu Jun 15, 2017 9:12 am |
If you read the manual your use of spi_read are wrong for master.
Quote: | Return a value read by the SPI. If a value is passed to the spi_read() the data will be clocked out and the data received will be returned. If no data is ready, spi_read() will wait for the data is a SLAVE or return the last DATA clocked in from spi_write().
If this device is the MASTER then either do a spi_write(data) followed by a spi_read() or do a spi_read(data). These both do the same thing and will generate a clock. If there is no data to send just do a spi_read(0) to get the clock.
rfjhh
Posted: Thu Jun 15, 2017 10:11 pm |
I've modified the code as follows:
MASTER
#include<16f887.h>
#include<LCD.c>
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
int8 valor;
set_tris_e(0xfe);
lcd_gotoxy(1,1);
while(true)
lcd_gotoxy(1,2);
output_high(PIN_E0); // SS
valor=spi_read(0x96);
delay_ms(2);
lcd_gotoxy(1,2);
output_low(PIN_E0);
SLAVE:
#include<16f886.h>
#include<LCD.c>
#use fast_io(B)
#use fast_io(C)
#use standard_io(A)
/* RC3 SPI CLK
RC4 SPI SDI
RC5 SPI SDO
RC0 SPI SS
int8 valor;
set_tris_b(0xff);
set_tris_c(0xdf);
setup_spi(SPI_SLAVE | SPI_H_TO_L | SPI_CLK_DIV_16);
while(true)
valor = input_b();
spi_write(valor);
Now I have the clock signal, but nothing happens from the slave to the master. |
