Compiler option +CC
davegreen
Compiler option +CC
PostPosted: Fri Jun 09, 2017 12:28 am     Reply with quote
Does anyone know what command line option +CC does? I can't find any documentation, except for a vague reference in a FAQ for multiple compilation units.
PostPosted: Fri Jun 09, 2017 1:06 am     Reply with quote
What is wrong with the FAQ's explanation ?
When building a project, each unit being used in the project has its own
error file. When using a *.bat file to do the unit compilations, it may be
useful to terminate the process on the first error. Using the +CC
command line option, the compiler will return an error code if the
compilation fails
