SD file error
2pipo
SD file error
PostPosted: Sat Apr 22, 2017 8:57 am     Reply with quote
Hi there
I'm creating a project in which I save data into a SD card. I'm using PIC 18f2685 and 4.104 version of the CCS.
I also use a system to communicate from the 5V pic to the 3.3V SD.
I'm using the libraries from CCS (fat.c and mmcsd.c)
The problem that i have is that I have a maximum size of file which is about 450 characters. Do you know how can I solve it?
Here is the code:
Coses a fer:
Preparar per rebre dades des de portàtil==> Fet
Crear arxiu nou diferent cada cop==> Fet
Optimització sistema guardar dades
#include "C:\Users\pau_v\Dropbox\Pau\Estudis\Formula Student 2016-2017\TFG\programa_final\main.h"
#define CAN_USE_EXTENDED_ID FALSE
#include <can-18xxx8.c>
#use rs232(baud=115200, UART1)
char mystring[20];
char myss[15];
int i = 0,alta = 1,alta_ant=0,transmetre = 0;
int k = 0;
int kk=0;
int16 num = 0;
int8 index=0,indexx=0;
unsigned int16 cobid=0;
unsigned int8 lengthCAN=0;
//char filleName[15] = "file.txt";
long long mylong;
char *fileName;
unsigned int8 array[10][150];
unsigned int Total_v=0,Min_v=0,Max_v=0,Min_t=0,Max_t=0,Min_l=0,Max_l=0,Throtle_1=0,Throtle_2=0,Brake=0,Steering=0,Sus_d_e=0,Sus_d_d=0,Sus_r_e=0,Sus_r_d=0,Shut_1=0,Vel_d_d=0,Vel_d_e=0;
char g_CWD[2] = "/";
int m = 0;
char nume;
int1 variable;
int t=0;
int ttt = 0;
int counter_msg=0;
int1 can0x80=0;
int1 can0x91=0;
#int_canrx0
void canrx0_int ( ) {
   k++;
   cobid=((unsigned int16)RXB0SIDH << 3)|((RXB0SIDL & 0xE0)>>5);
   lengthCAN =  (unsigned int8)RXB0DLC & 0xF;
   array[0][k]=cobid;
   array[1][k]=lengthCAN;
   array[2][k]=RXB0D0;
   array[3][k]=RXB0D1;
   array[4][k]=RXB0D2;
   array[5][k]=RXB0D3;
   array[6][k]=RXB0D4;
   array[7][k]=RXB0D5;
   array[8][k]=RXB0D6;
   array[9][k]=RXB0D7;
   if(cobid == 0x80){
      ttt=1;
      can0x80=1;
      kk=1;
      index++;
      indexx++;
      if(indexx >= 20){
         indexx =0;
      if(index >= 10){
         index = 0;
      variable =  RXB0D0;
      //delay_ms(8);
   if(cobid == 0x91){//Votatge
      can0x91=1;
      Min_v=make16(RXB0D0,RXB0D1);
      Max_v=make16(RXB0D2,RXB0D3);
      Total_v=make32(RXB0D4,RXB0D5,RXB0D6,RXB0D7);
   if(cobid == 0x92){//Sensors pedals i direcció
      Throtle_1 = make16(RXB0D0,RXB0D1);
      Throtle_2 = make16(RXB0D2,RXB0D3);
      Brake = make16(RXB0D4,RXB0D5);
      Steering = make16(RXB0D6,RXB0D7);
   if(cobid == 0x93){//Sensors suspensió i velocitat
      Sus_d_d = make16(RXB0D0,RXB0D1);
      Sus_d_e = make16(RXB0D2,RXB0D3);
      Vel_d_d = RXB0D4;
      Vel_d_e = RXB0D5;
   if(cobid == 0x94){//Shutdown i info inversors
      Shut_1 = RXB0D0;
   //if(cobid == 0x95)//Accelerometre, giro, susp darrera
   if(cobid == 0x97){//Temp package, current
      Min_t = make16(RXB0D0,RXB0D1);
      Max_t = make16(RXB0D2,RXB0D3);
      Min_l = make16(RXB0D4,RXB0D5);
      Max_l = make16(RXB0D6,RXB0D7);
   if(cobid == 0x90)//engegar alta,guardar o transmetre
   if(cobid == 0x96){//Susp rera
      Sus_r_d = make16(RXB0D0,RXB0D1);
      Sus_r_e = make16(RXB0D2,RXB0D3);
   RXB0CON.RXFUL = 0;
#include <stdlib.h> // for atoi32
//meda library, a compatable media library is required for FAT.
#use fast_io(c)
#include "mmcsd.c"
#include "fat.c"
#include <input.c>
/// Useful Defines ///
#define COMMAND_SIZE 10
#define NUM_COMMANDS 13*/
/// Global Variables ///
//Make file
void MakeFile(char *fileName)
   printf("\r\nMaking file '%s': ", fileName);
   if(mk_file(fileName) != GOODEC)
      printf("Error creating file");
      return;
   printf("OK");
// Print file
void PrintFile(char *fileName){
   FILE stream;
   if(fatopen(fileName, 'r', &stream) != GOODEC)
      printf("\r\nError opening file");
      return;
   printf("\r\n");
   fatprintf(&stream);
   fatclose(&stream);
//Display la info
void DisplayDirectory(char *dir)
   disp_folder_contents(dir);
void main(){
   disable_interrupts(GLOBAL);
   can_init();
   can_set_mode(CAN_OP_CONFIG);
   BRGCON1.brp=1;
   BRGCON1.sjw=1;
   BRGCON2.prseg=2;
   BRGCON2.seg1ph=7;
   BRGCON2.sam=FALSE;
   BRGCON2.seg2phts=FALSE;
   BRGCON3.seg2ph=6;
   BRGCON3.wakfil=FALSE;
   CIOCON = 0x20;
   can_set_mode(CAN_OP_NORMAL);
   char fileName[25];
   int i;   // pointer to the buffer
   i = fat_init();
   if (i){
      printf("\r\n\nERROR INITIALIZING FAT\r\n\n");
      output_low(PIN_A5);
   else{
      printf("\r\n\n FAT INITIALIZED\r\n\n");
      output_high(PIN_A5);
   DisplayDirectory(g_CWD);
   //m=23;
   sprintf(nume,"%u",m);
   //fileName = "file";
   strcpy(mystring,g_CWD);
   //strcat(mystring,fileName);
   strcat(mystring,nume);
   /*fileName=".txt";
   strcat(mystring,fileName);*/
   FILE stream;
   MakeFile(mystring);
   enable_interrupts(int_canrx0);
   while(true){
      output_bit(PIN_A2,variable);
      if(transmetre == 1){
         PrintFile(mystring);
      if(indexx=8 && can0x80==1 && can0x91==1){
            can0x80=0;
            can0x91=0;
      alta_ant=alta;
      if(index == 9 & alta == 1 & kk==1){//en l'instant 9 guarda les dades que han passat durant tot el mig segon
         kk=0;
         can0x80=0;
         can0x91=0;
         t=1;
         counter_msg++;
         if(fatopen(mystring, "a", &stream) != GOODEC){
            printf("Error opening file");
            return;
         else{
            printf("Open");
         for(i=0;i<k;i++){
            for(num = 0; num<=9; num++){
               sprintf(myss,"%u",array[num][i]);
               fatputs(myss, &stream);
               fatputs(",", &stream);
               array[num][i]=0;
            fatputs("\r\n", &stream);
         sprintf(myss,"%u",counter_msg);
         k=0;
         /*fileName = "file";
         fileName=".txt";
      if((index == 0 | (alta==0 & alta_ant==1 )) & kk==1 & t==1){//al començar el següent segon tanca l'arxiu. Aixó es fa perque duri menys de 50 ms tota l'operació de guardar dades.
            kk=0;
            can0x80=0;
            can0x91=0;
            if(fatclose(&stream) != GOODEC)
               printf("Error closing file");
               return;
            printf("Close");
      if(ttt==1){
         printf("%u",alta);
         printf(",");
         printf("%u",k);
         printf(",");
         printf("%u",index);
         printf(",");
         printf("%u",kk);
         printf(",");
         printf("%u",can0x80);
         printf(",");
         printf("%u",can0x91);
         printf(",");
         printf("%u",array[2][k]);
         printf("\r\n");
         ttt=0;
PostPosted: Sat Apr 22, 2017 5:44 pm     Reply with quote
There is a sticky in the code library forum with all the bug fixes in it.
Try using that version instead.
2pipo
PostPosted: Tue Apr 25, 2017 10:04 am     Reply with quote
I finally got the error, the library you told me had some errors and didn't work in my project.
The problem i had was that i formatted the SD in a wrong way.
