apakSeO
Joined: 07 Dec 2016 Posts: 60 Location: Northeast USA
[SOLVED]Basic float type cannot be assigned a value |
Posted: Wed Mar 22, 2017 8:47 am |
CCS v5.070
MPLAB X IDE v3.40
PIC24FJ256GB210
I am trying to figure out if I have a compiler misunderstanding or if MPLAB is somehow not playing nicely with floats.
I am trying to do some basic floating point arithmetic and then set up a Watch within MPLAB's Debug mode to test my assumptions. Entirety of test code is below:
#include <24FJ256GB210.h>
#fuses NOWDT,NOWRT,NOPROTECT//,NOWPDIS,NOWPCFG,NOIESO,NOWPFP
#device PIC24FJ256GB210 ICD=TRUE
#use delay(INTERNAL=8MHz, CLOCK=8MHz)
float a;
float b;
float c;
void main (void)
a = 1.5;
b = 2.5;
c = a + b;
while(1){
output_toggle(PIN_D0); // Let me know PIC is operating
delay_ms(250);
return;
When I pause the debugger, the Watches / Variables get updated and I can see the current value of a variable. Using int8 or int16 or longs seems to be working fine. Using floats as in the code above shows me this consistently:
Optimizations in CCS are set to 0, and variables a,b,c are global. So I'm not certain what is happening here and why a,b,c never take on a value. Anyone have insight into if this is an MPLAB issue or a CCS idiosyncrasy?
Posted: Wed Mar 22, 2017 9:27 am |
What type are you setting the watch up 'as'?.
MPLAB-X supports a lot of different types for floats.
For the PIC16/18, you need to select MCHP float, with the LSB first option.
For the PIC24/30/33, you need to select Float32 (or 64 for the CCS 'double'). Again LSB first.
Right click, 'display value as'.
You really need to be asking on the MPLAB forum. People there will know MPLAB-X. We mainly try to avoid it, since it is so unreliable (every version I try has different bugs from the one before....). |
apakSeO
Posted: Wed Mar 22, 2017 11:38 am |
Ttelmah wrote: | What type are you setting the watch up 'as'?.
Thanks again, Ttelmah. I could not discern if this was a CCS issue or an MPLAB issue, so I posted here first.
It was indeed an issue with MPLAB. Originally, the 'display value as' was set to "Microchip Float". I had to set 'display value as' to "IEEE Float" in order to see the proper values for my floats.
Thanks for the tip, I will look more into these display value types. |
