knowing cycle program time
jpts
PostPosted: Sun Mar 12, 2017 12:56 pm     Reply with quote
How the best way to measure the program run cycle time. PIC16F
Means how long a program takes to 1 cycle completed...
PostPosted: Sun Mar 12, 2017 1:21 pm     Reply with quote
This post explains how to use the MPLAB (vs. 8.92) Stopwatch feature
to find out how many cycles (and microseconds) it takes to execute a
block of code:
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
PostPosted: Sun Mar 12, 2017 1:33 pm     Reply with quote
PCM P's link is one 'best' way..
another is 'old school'.
Crack open the PIC datasheet, locate the instruction set, printout your code( the listing file), then lookup the instructions and tabulate the times to execute.
Yes, it'll take longer but you'll get a far better understanding on how PICs work.
jpts
PostPosted: Sun Mar 12, 2017 2:15 pm     Reply with quote
can have this time to be printed ? available to use in program ?
ex:
clock = 4Mhz
int x, y, z
x = y * z;
x = y + z;
delay_ms(10);
x = x + 100;
Whats the time of each cycle program...??
printf ( program time cycle) ????
PostPosted: Sun Mar 12, 2017 2:32 pm     Reply with quote
Not possible....
In the manual for the compiler, you will find a section giving, the times for the maths operations, for different numeric types. These are the 'core' times, but ignore any overheads, like converting between source types etc..
The printf will depend on the speed of whatever you send the data to, and how it is sent. Amount of buffer for serial etc..
Even with all of these calculated, the times will still change though. Things specific to your program. So (for instance), how much time it takes to load a variable may well differ, if a bank switch has to occur to access this variable.
Hence the MPLAB solution, or simple toggle a pin before and after the operation, and measure how long the pulse is this gives.
jpts
PostPosted: Sun Mar 12, 2017 2:49 pm     Reply with quote
understand...but how to implement frequency for instance...where need pulse / second...or pulses / period of time...
for example:
setup_timer_0(RTCC_EXT_L_TO_H|RTCC_DIV_1|RTCC_8_bit);
pulse = get_timer0();
how measure the frequency pulse in ?
PostPosted: Sun Mar 12, 2017 4:45 pm     Reply with quote
These threads tell how to use the CCP module to measure frequency:
Determining square-wave frequency input into pic:
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
CCP / 24 bit timer / 1hz to 150 hz range:
http://www.ccsinfo.com/forum/viewtopic.php?t=33153
Rob1955
PostPosted: Sun Mar 12, 2017 10:39 pm     Reply with quote
ex:
clock = 4Mhz
int x, y, z
x = y * z;
x = y + z;
delay_ms(10);
x = x + 100;
new to PIC here but shouldn't this answer this specific query:
set_timer1(0);
int16 HowLong = get_timer1();
//printf value after converting it to (us) or (ms) if desired.
//and printf time is not included in above time.
and maybe extending the timer to 24 bit if suspect timer will overflow depending on the prescaler and clock being used. This way interrupt cycle time is also included in the overall time it took the PIC to cover measured section.
