Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
delay_ms problems with the command
Andr3s
PostPosted: Sun May 01, 2016 4:45 pm     Reply with quote
Hey guys ... I am new to pic controllers and scheduled ccs ... in a moment of madness that not pressed or gave accept that now the compiler does not recognize the command delay_ms... even in the libraries...
uninstall it and install again but the problem is ... I hope you can help me
PostPosted: Sun May 01, 2016 4:54 pm     Reply with quote
show us a small,compilable program that has the problem, as well as compiler version and PIC type.
also post the 'error message' that comes up.
Jay
Andr3s
PostPosted: Sun May 01, 2016 4:58 pm     Reply with quote
https://www.flickr.com/photos/fcsuil/26154147384/in/dateposted-public/
Andr3s
PostPosted: Sun May 01, 2016 5:00 pm     Reply with quote
[/img]
[/img]
the link is an example
ezflyr
PostPosted: Sun May 01, 2016 5:16 pm     Reply with quote
Well, I'd say it's because you have neglected to tell the compiler the clock you are using upon which the delay_ms is calculated. You are also missing your fuses!
So, you need something like this:
#include <16F877a.h>
This should allow the code to compile, but it may not match your actual hardware configuration. This code is for an external 20MHz crystal.
Does that help the issue?
John
If it's worth doing, it's worth doing in real hardware!
Andr3s
PostPosted: Sun May 01, 2016 5:21 pm     Reply with quote
if that happens thanks is all afternoon looking for other options and was so thank you very much for the solution
thank you very much
