16F819 setting frequency for internal oscillator
Blair Allen
PostPosted: Wed Jun 04, 2003 12:18 pm     Reply with quote
I am tring to set the oscillator frequency when using the fuse INTRC_IO for the 16F819. I am not sure how to write to OSCCON to set the frequency. Another question is when I am running in stand-alone am I able to use RB4 as an I/O?
Original Post ID: 144515034
allen_m
Re: 16F819 setting frequency for internal oscillator
PostPosted: Wed Jun 04, 2003 1:54 pm     Reply with quote
:=I am tring to set the oscillator frequency when using the fuse INTRC_IO for the 16F819. I am not sure how to write to OSCCON to set the frequency. Another question is when I am running in stand-alone am I able to use RB4 as an I/O?
To set OSCTUNE do the following in the definition / preamble area
#byte OSCCON = 0x8F; // set the address
Then early in main set it to the frequency you wish ...
OSCCON = 0x70; // 8MHz operation
Re RB4, yes you can use it as IO (by standalone I assume you mean no I2c or SPI).
Allen M.
Original Post ID: 144515037
