Code missing in .LST file
Thomas Hartmann
PostPosted: Mon Jun 02, 2003 10:31 am     Reply with quote
Hello all,
I am missing code ( functions ) in my list file.
I can not set break points in these functions when debugging with MPLAB 5.70.40 and MPLAB-ICD.
Nonetheless the missing functions are somehow executed because I toggle an output there. I can see the LED blinking ...
Questions 1:
What does the compiler do with that "missing" code ?
Can I trust the compiler on that ?
Why can't I set breakpoints ?
Also I see some "funny" behaviour within these functions:
- I call another function read_eeprom( LENGTH_1 )
@ #define LENGTH_1 8
=> inside the function read_eeprom the parameter reads 2, not 8
- I call set_adc_channel( CHAN_MV )
@ #define CHAN_MV 1
=> ADC 0 is read, not ADC 1, as expected
I replaced the defines with hard coded numbers ( read_eeprom( 8 ) and set_adc_channel( 1 ) ) and all works fine.
Questions 2:
Did anyone experience a similar bahviour ?
Why does the compiler sometimes mess up defines ?
Tnx for your replies
Thomas
Example code from the .LST file:
0000 07453 .................... if( n1ExecuteMeasurement )
0CE0 1F3C 07454 BTFSS 3C.6
0CE1 2CE5 07455 GOTO 4E5
0000 07456 .................... {
0000 07457 .................... n1ExecuteMeasurement = 0;
0CE2 133C 07458 BCF 3C.6
0000 07459 ....................
0000 07460 .................... measureTemp();
0CE3 2A58 07461 GOTO 258
0000 07462 .................... measureMv();
0CE4 2AB5 07463 GOTO 2B5
0000 07464 ....................
From my .h-File:
#separate void measureTemp(void);
#separate void measureMv(void); --------------------------------------------
From the tree:
³ ÃÄmeasureTemp 1/93 Ram=13
³ ³ ÃÄread_eeprom_data 0/47 Ram=7
³ ³ ÀÄ@DIVS1616 1/81 Ram=6
³ ÀÄmeasureMv 1/118 Ram=9
³ ÃÄsetSelftestADCError 0/22 Ram=1
³ ÀÄsetSelftestADCError 0/22 Ram=1=============================================
Original Post ID: 144514962
Tomi
Re: Code missing in .LST file
PostPosted: Mon Jun 02, 2003 10:45 am     Reply with quote
Seems that your functions are compiled as INLINE regardless of your #separate directive.
Try to separate the compiler directive from function definition:
#separate
Instead of "#separate void measureTemp(void);"
:=Hello all,
:=I am missing code ( functions ) in my list file.
:=I can not set break points in these functions when debugging with MPLAB 5.70.40 and MPLAB-ICD.
:=Nonetheless the missing functions are somehow executed because I toggle an output there. I can see the LED blinking ...
:=Questions 1:
:=What does the compiler do with that "missing" code ?
:=Can I trust the compiler on that ?
:=Why can't I set breakpoints ?
:=Also I see some "funny" behaviour within these functions:
:=- I call another function read_eeprom( LENGTH_1 )
:= @ #define LENGTH_1 8
:= => inside the function read_eeprom the parameter reads 2, not 8
:=- I call set_adc_channel( CHAN_MV )
:= @ #define CHAN_MV 1
:= => ADC 0 is read, not ADC 1, as expected
:=I replaced the defines with hard coded numbers ( read_eeprom( 8 ) and set_adc_channel( 1 ) ) and all works fine.
:=Questions 2:
:=Did anyone experience a similar bahviour ?
:=Why does the compiler sometimes mess up defines ?
:=Tnx for your replies
:= Thomas
:=Example code from the .LST file:
:=0000 07453 .................... if( n1ExecuteMeasurement )
:=0CE0 1F3C 07454 BTFSS 3C.6
:=0CE1 2CE5 07455 GOTO 4E5
:=0000 07456 .................... {
:=0000 07457 .................... n1ExecuteMeasurement = 0;
:=0CE2 133C 07458 BCF 3C.6
:=0000 07459 ....................
:=0000 07460 .................... measureTemp();
:=0CE3 2A58 07461 GOTO 258
:=0000 07462 .................... measureMv();
:=0CE4 2AB5 07463 GOTO 2B5
:=0000 07464 ....................
:=From my .h-File:
:=#separate void measureTemp(void);
:=#separate void measureMv(void); --------------------------------------------
:=From the tree:
:= ³ ÃÄmeasureTemp 1/93 Ram=13
:= ³ ³ ÃÄread_eeprom_data 0/47 Ram=7
:= ³ ³ ÀÄ@DIVS1616 1/81 Ram=6
:= ³ ÀÄmeasureMv 1/118 Ram=9
:= ³ ÃÄread_eeprom_data 0/47 Ram=7
:= ³ ÃÄsetSelftestADCError 0/22 Ram=1
:= ³ ÀÄsetSelftestADCError 0/22 Ram=1=============================================
Original Post ID: 144514963
