ASM routine for multiplication
acid
PostPosted: Mon May 26, 2003 8:24 am     Reply with quote
Hello
I have downloaded this routine from www.piclist.com
<a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank">http://www.piclist.com/cgi-bin/constdivmul.exe</a>
it multiplies 1.333 * int
; Round = no
; ALGORITHM:
; Clear accumulator
; Add input * 1 to accumulator
; Add input / 4 to accumulator
; Add input / 16 to accumulator
; Add input / 64 to accumulator
; Move accumulator to result
; Approximated constant: 1.32813, Error: 0.365716 \%
; Input: ACC0, 8 bits
; Output: ACC0 .. ACC1, 9 bits
; Code size: 16 instructions
; cblock
; ACC0
; ACC1
; endc
;copy accumulator to temporary
movf ACC0, w
;shift accumulator right 2 times
clrc
rrf ACC0, f
clrc
rrf ACC0, f
;add temporary to accumulator
addwf ACC0, f
rrf ACC0, f
clrc
rrf ACC0, f
addwf ACC0, f
rrf ACC0, f
clrc
rrf ACC0, f
addwf ACC0, f
clrf ACC1
rlf ACC1, f
But I have problems. CCS not compile the code it return an error for clrc and cblock instruction
Can you help me ?
THANK!!
Original Post ID: 144514761
Tomi
Re: ASM routine for multiplication
PostPosted: Mon May 26, 2003 8:59 am     Reply with quote
clrc = Clear Carry
You can do this (16F877):
#define clrc bcf 0x03,0 in assembler
or
bit_clear(*0x03,0) in C
If you have another PIC (e.g. any 18F ) then check the address of the STATUS register.
You don't need cblock instruction. It reserves space for internal accumulators. Instead of this, declare ACC0 and ACC1 at the normal C part (e.g. char ACC0,ACC1; ). Then you can use these variables by names in assy parts.
:=Hello
:=I have downloaded this routine from www.piclist.com
:= <a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank"> <a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank">http://www.piclist.com/cgi-bin/constdivmul.exe</a></a>
:=it multiplies 1.333 * int
:=; Round = no
:=; ALGORITHM:
:=; Clear accumulator
:=; Add input * 1 to accumulator
:=; Add input / 4 to accumulator
:=; Add input / 16 to accumulator
:=; Add input / 64 to accumulator
:=; Move accumulator to result
:=; Approximated constant: 1.32813, Error: 0.365716 \%
:=; Input: ACC0, 8 bits
:=; Output: ACC0 .. ACC1, 9 bits
:=; Code size: 16 instructions
:=; cblock
:=; ACC0
:=; ACC1
:=; endc
:=;copy accumulator to temporary
:= movf ACC0, w
:=;shift accumulator right 2 times
:= clrc
:= rrf ACC0, f
:= clrc
:= rrf ACC0, f
:=;add temporary to accumulator
:= addwf ACC0, f
:= rrf ACC0, f
:= clrc
:= rrf ACC0, f
:= addwf ACC0, f
:= rrf ACC0, f
:= clrc
:= rrf ACC0, f
:= addwf ACC0, f
:= clrf ACC1
:= rlf ACC1, f
:=But I have problems..Css not compile the code it return un error for clrc and cblock istruction
:=Can you help me ?
:=THANK!!
Original Post ID: 144514764
acid
PostPosted: Tue May 27, 2003 6:20 am     Reply with quote
ok!
It save 57 word in the my program!
THANKS
:=clrc = Clear Carry
:=You can do this (16F877):
:=#define clrc bcf 0x03,0 in assembler
:=or
:=bit_clear(*0x03,0) in C
:=If you have another PIC (e.g. any 18F ) then check the address of the STATUS register.
:=You don't need cblock instruction. It reserves space for internal accumulators. Instead of this, declare ACC0 and ACC1 at the normal C part (e.g. char ACC0,ACC1; ). Then you can use these variables by names in assy parts.
:=:=Hello
:=:=I have downloaded this routine from www.piclist.com
:=:= <a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank"> <a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank"> <a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank">http://www.piclist.com/cgi-bin/constdivmul.exe</a></a></a>
:=:=it multiplies 1.333 * int
:=:=; Round = no
:=:=; ALGORITHM:
:=:=; Clear accumulator
:=:=; Add input * 1 to accumulator
:=:=; Add input / 4 to accumulator
:=:=; Add input / 16 to accumulator
:=:=; Add input / 64 to accumulator
:=:=; Move accumulator to result
:=:=; Approximated constant: 1.32813, Error: 0.365716 \%
:=:=; Input: ACC0, 8 bits
:=:=; Output: ACC0 .. ACC1, 9 bits
:=:=; Code size: 16 instructions
:=:=; cblock
:=:=; ACC0
:=:=; ACC1
:=:=; endc
:=:=;copy accumulator to temporary
:=:= movf ACC0, w
:=:=;shift accumulator right 2 times
:=:= clrc
:=:= rrf ACC0, f
:=:= clrc
:=:= rrf ACC0, f
:=:=;add temporary to accumulator
:=:= addwf ACC0, f
:=:= rrf ACC0, f
:=:= clrc
:=:= rrf ACC0, f
:=:= addwf ACC0, f
:=:= rrf ACC0, f
:=:= clrc
:=:= rrf ACC0, f
:=:= addwf ACC0, f
:=:= clrf ACC1
:=:= rlf ACC1, f
:=:=But I have problems..Css not compile the code it return un error for clrc and cblock istruction
:=:=Can you help me ?
:=:=THANK!!
Original Post ID: 144514777
