EE_PROM addressing above addr 255
Phil G
PostPosted: Thu May 22, 2003 6:54 am     Reply with quote
The PIC18F6720 has 1K of data EEPROM; How can I address it if the CCS functions for reading and writing take only an 8-bit address?
Phil G
Original Post ID: 144514669
Tomi
Re: EE_PROM addressing above addr 255
PostPosted: Thu May 22, 2003 7:06 am     Reply with quote
The trivial solution is:
void MyWrite_eeprom(unsigned long addr,char data)
#byte addrL = addr
#byte addrH = addr+1
*0x0FAA = addrH; // load upper addr byte
Write_eeprom(addrL,data);
char MyRead_eeprom(unsigned long addr)
#byte addrL = addr
return read_eeprom(addrL);
:=The PIC18F6720 has 1K of data EEPROM; How can I address it if the CCS functions for reading and writing take only an 8-bit address?
:=Phil G
Original Post ID: 144514670
Woody
PostPosted: Fri May 23, 2003 1:41 am     Reply with quote
Although the CCS documentation and help file state that the parameter to the EEPROM library functions is an int, a test with PCWH version 3.158 shows that it is correctly using a long parameter for the 18F6720.
Apparently the documentation has not caught up with the compiler capabilities.
#include <18F6720.h>
void main (void)
long a = 700;
write_eeprom (a, 55 );
Original Post ID: 144514691
rret
PostPosted: Tue Jul 22, 2003 1:14 pm     Reply with quote
:=The trivial solution is:
:=void MyWrite_eeprom(unsigned long addr,char data)
:=#byte addrL = addr
:=#byte addrH = addr+1
:=*0x0FAA = addrH; // load upper addr byte
:=Write_eeprom(addrL,data);
:=char MyRead_eeprom(unsigned long addr)
:=return read_eeprom(addrL);
:=:=The PIC18F6720 has 1K of data EEPROM; How can I address it if the CCS functions for reading and writing take only an 8-bit address?
:=:=Phil G
I understand where you get the 0x0FAA, but what do you pass in for the "addr" parameter when you call MyWrite_eeprom()?
(Say you wish to write a byte to the first eeprom "cell".)
Original Post ID: 144516254
