Can't stop a countdown timer.
Forest
PostPosted: Tue May 20, 2003 2:11 am     Reply with quote
I have a basic countdown clock using timer 1 and and external crystal.
How do I stop the timer at 0. I've tried all sorts and haven't had any luck.
Ideas??
#include <16f877.h>
#fuses hs,nowdt,noprotect,put,nowrt,nolvp
#use RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=,bits=8)
#include <ccslcd2.c>
#define INTS_PER_SECOND 32768
long seconds=60;
long minutes=34;
short one_sec_fl;
#int_timer1
clock_isr() {
one_sec_fl = 1;
set_timer1(0x7fff);
main() {
delay_ms(6);
setup_timer_1( T1_DIV_BY_1 | T1_EXTERNAL | T1_CLK_OUT );
printf(lcd_putc,"\f35:00");
lcd_gotoxy(1,2);
printf("\r\npress a key");
Printf(lcd_putc,"Press a key");
getc();
while(true)
if (one_sec_fl)
--seconds;
if (seconds==-1)
--minutes;
seconds=59;
one_sec_fl = 0;
lcd_gotoxy(1,1);
printf(lcd_putc,"\%02ld:\%02ld",minutes,seconds);
Original Post ID: 144514573
Tomi
Re: Can't stop a countdown timer.
PostPosted: Tue May 20, 2003 2:52 am     Reply with quote
<font face="Courier New" size=-1>"seconds" is unsigned by default so your
if (seconds==-1)
never becomes true. Test it for 0xFFFF (if it is a 16-bit long indeed) instead of -1.
To completely stop Timer1 you can use
:=I have a basic countdown clock using timer 1 and and external crystal.
:=How do I stop the timer at 0. I've tried all sorts and haven't had any luck.
:=Ideas??
:=#include <16f877.h>
:=#fuses hs,nowdt,noprotect,put,nowrt,nolvp
:=#use delay(clock=4000000)
:=#use RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=,bits=8)
:=#include <ccslcd2.c>
:=#define INTS_PER_SECOND 32768
:=long seconds=60;
:=long minutes=34;
:=short one_sec_fl;
:=#int_timer1
:=clock_isr() {
:= one_sec_fl = 1;
:= set_timer1(0x7fff);
:=main() {
:= lcd_init();
:= delay_ms(6);
:= setup_timer_1( T1_DIV_BY_1 | T1_EXTERNAL | T1_CLK_OUT );
:= enable_interrupts(INT_TIMER1);
:= enable_interrupts(GLOBAL);
:= printf(lcd_putc,"\f35:00");
:= lcd_gotoxy(1,2);
:= printf("\r\npress a key");
:= Printf(lcd_putc,"Press a key");
:= getc();
:=while(true)
:= if (one_sec_fl)
:= --seconds;
:= if (seconds==-1)
:= --minutes;
:= seconds=59;
:= one_sec_fl = 0;
:= lcd_gotoxy(1,1);
:= printf(lcd_putc,"\%02ld:\%02ld",minutes,seconds);
:=}</font>
Original Post ID: 144514577
Forest
PostPosted: Tue May 20, 2003 3:07 am     Reply with quote
The "=if (seconds==-1)" is only part there to increment minutes. It seems to work OK but I see what u mean.
Where would I insert the =disable_interrupts(INT_TIMER1);??
I've been trying heaps of diffent spots but can't get it right.
I just want the timer to count down and then stop, so that I can go on with other things.
cheers
:=<font face="Courier New" size=-1>"seconds" is unsigned by default so your
:=if (seconds==-1)
:=never becomes true. Test it for 0xFFFF (if it is a 16-bit long indeed) instead of -1.
:=To completely stop Timer1 you can use
:=disable_interrupts(INT_TIMER1);
:=:=I have a basic countdown clock using timer 1 and and external crystal.
:=:=How do I stop the timer at 0. I've tried all sorts and haven't had any luck.
:=:=Ideas??
:=:=#include <16f877.h>
:=:=#fuses hs,nowdt,noprotect,put,nowrt,nolvp
:=:=#use delay(clock=4000000)
:=:=#use RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=,bits=8)
:=:=#include <ccslcd2.c>
:=:=#define INTS_PER_SECOND 32768
:=:=long seconds=60;
:=:=long minutes=34;
:=:=short one_sec_fl;
:=:=#int_timer1
:=:=clock_isr() {
:=:= one_sec_fl = 1;
:=:= set_timer1(0x7fff);
:=:=main() {
:=:= lcd_init();
:=:= delay_ms(6);
:=:= setup_timer_1( T1_DIV_BY_1 | T1_EXTERNAL | T1_CLK_OUT );
:=:= enable_interrupts(INT_TIMER1);
:=:= enable_interrupts(GLOBAL);
:=:= printf(lcd_putc,"\f35:00");
:=:= lcd_gotoxy(1,2);
:=:= printf("\r\npress a key");
:=:= Printf(lcd_putc,"Press a key");
:=:= getc();
:=:=while(true)
:=:= if (one_sec_fl)
:=:= --seconds;
:=:= if (seconds==-1)
:=:= --minutes;
:=:= seconds=59;
:=:= one_sec_fl = 0;
:=:= lcd_gotoxy(1,1);
:=:= printf(lcd_putc,"\%02ld:\%02ld",minutes,seconds);
:=:=}</font>
Original Post ID: 144514579
Tomi
PostPosted: Tue May 20, 2003 3:35 am     Reply with quote
:=Where would I insert the =disable_interrupts(INT_TIMER1);??
It is depends on what you want Smile
If it is a downcounter then you can test for both minutes and seconds are zero:
if (!(seconds--)) { // test for zero BEFORE decrement
seconds = 59;
if (!(minutes--)) { // if it is true the minutes=0 before decrement and the second is just after zero
disable_interrupts(INT_TIMER1); // disable further ITs
elapsed = TRUE; // set a flag to indicate the end of
Original Post ID: 144514580
forest
PostPosted: Tue May 20, 2003 11:45 pm     Reply with quote
Thanks Tomi - got it working.
:=:=Where would I insert the =disable_interrupts(INT_TIMER1);??
:=It is depends on what you want <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=If it is a downcounter then you can test for both minutes and seconds are zero:
:=if (!(seconds--)) { // test for zero BEFORE decrement
:= seconds = 59;
:= if (!(minutes--)) { // if it is true the minutes=0 before decrement and the second is just after zero
:= disable_interrupts(INT_TIMER1); // disable further ITs
:= elapsed = TRUE; // set a flag to indicate the end of
Original Post ID: 144514615
