Pic16f87x vs. Pcf8583
tony_20
PostPosted: Tue May 13, 2003 7:08 am     Reply with quote
Hallo!
How do I connect the Pic16f87x with pcf8583.
I know that pin 5 & 6 (SDA & SCL) connect to RC3 and RC4 on the Pic. Where do I connect pin 3 (A0), to GND??? And should pin 7 (INT*) be connected or not???
Original Post ID: 14407
Tomi
Re: Pic16f87x vs. Pcf8583
PostPosted: Tue May 13, 2003 9:00 am     Reply with quote
A0: if you don't have any other I2C devices like EEPROM then you can tie it to GND and access the chip at address 0xA0.
If you have any additional chip on the I2C (especially a 24XX memory with address 0xA0) then connect it to Vcc to make free the 0xA0 address and access the chip as 0xA2 I2C base address.
INT: Connect it to PIC only if you want to use the output for any alarm purposes.
:=Hallo!
:=How do I connect the Pic16f87x with pcf8583.
:=I know that pin 5 & 6 (SDA & SCL) connect to RC3 and RC4 on the Pic. Where do I connect pin 3 (A0), to GND??? And should pin 7 (INT*) be connected or not???
Original Post ID: 14409
