Switch between Fast and Slow Mode of i2c
Spaark
PostPosted: Wed Apr 30, 2003 2:19 am     Reply with quote
Is it possible to switch from the Slow-Mode to the Fast-Mode of i2c in the Programmcode? And how if it is possible?
I now use #use i2c(master,sda=PIN_C4, scl=PIN_C3, SLOW) and want to switch to #use i2c(master,sda=PIN_C4, scl=PIN_C3, FAST) when i press a key.
Thanks.
Spaark
Original Post ID: 14077
Re: Switch between Fast and Slow Mode of i2c
PostPosted: Wed Apr 30, 2003 12:48 pm     Reply with quote
:=Is it possible to switch from the Slow-Mode to the Fast-Mode of i2c in the Programmcode? And how if it is possible?
:=I now use #use i2c(master,sda=PIN_C4, scl=PIN_C3, SLOW) and want to switch to #use i2c(master,sda=PIN_C4, scl=PIN_C3, FAST) when i press a key.
The easiest way is to use hardware i2c mode, and then change
the baudrate by writing to the SSPADD register.
Here is a sample program. If your crystal frequency is
different from 8 MHz, then change the #define statement
for Fosc so that it's set to your frequency.
<PRE>
#define Fosc 8000000 // I'm using a 8 MHz crystal
<BR>
#include "c:\Program Files\Picc\Devices\16F877.H"
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, NOLVP, PUT
#use delay(clock = Fosc)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
<BR>
// Tell the compiler to use hardware i2c.
#use i2c(Master, SDA=PIN_C4, SCL=PIN_C3, FORCE_HW, slow)
<BR>
// Calculate the i2c baudrate values, to program
// into the SSPADD register.
#define SLOW ((Fosc / (4 * 100000)) -1) // 100 KHz i2c clock
#define FAST ((Fosc / (4 * 400000)) -1) // 400 KHz i2c clock
<BR>
#byte SSPADD = 0x93 // Address of i2c baudrate register
<BR>
char c;
<BR>
delay_us(1);
<BR>
i2c_write(0x55);
<BR>
if(kbhit())
c = getc() & 0x5F;
<BR>
if(c == 'F') // If the F key is pressed, use Fast speed.
SSPADD = FAST;
<BR>
if(c == 'S') // If the S key is pressed, use Slow speed.
SSPADD = SLOW;
<BR>
<BR>
</PRE>
Original Post ID: 14091
