PIC10F222 Programming issue with ICD - U40
nehallove
PostPosted: Fri Jun 18, 2010 6:03 pm     Reply with quote
Hi Guys,
I am trying to program following code on the PIC10F222 chip.
#include <10F222.h>
#FUSES PROTECT                  //Code protected from reading
#FUSES MCLR                     //Master Clear pin enabled
#FUSES IOSC4                    //4MHz oscillator clock
#define IRDA_CLK   PIN_B1
#define PWR_CTRL   PIN_B2
#define PWR_ON()  output_low(PWR_CTRL)   //! Power On
#define PWR_OFF() output_high(PWR_CTRL)  //! Power Off
   unsigned int8 i;
   unsigned int8 count = 0;
   setup_adc(NO_ANALOGS);
   setup_adc_ports(NO_ANALOGS);
   PWR_OFF();
It gives me a first message saying: couldn't detect target automatically. I press yes to do programming (assuming that pic 10 is not smart enough for autodetection).
Then it gives me message that couldn't erase the flash voltage should be 5 V to erase the full code for protected fuse. I was using 3 V but later i tried with 5 V and result was the same.
Then it tries to program but then comes with verification error, saying that code is not transferred properly. I have everything connected properly. I am using previously programmed chip.
Thank you all.
nehal
nehal
nehallove
got new chip still doesn't program
PostPosted: Mon Jun 21, 2010 12:27 pm     Reply with quote
Hi All,
I am trying new chips still my ICD doesn't program PIC10F222.
Please help.
nehal
nehal
robomaniac
PostPosted: Sun Jul 11, 2010 12:09 pm     Reply with quote
It is a hardware problem, your code compiles and runs on my 10F222 breadboard setup.
My MCLR is 1K resistor
I have the SOT23 6 pin version so pin 1,3 and 6 are connected to the ICD.
Jérôme Demers
www.jeromedemers.com
