rs232 streams
hoorn666
rs232 streams
PostPosted: Thu Apr 24, 2003 7:25 am     Reply with quote
Hello foolks,
can someone help me with the following problem :
#use rs232(baud=4800, xmit=PIN_D5, rcv=PIN_D4, stream=NMEA_STREAM, RESTART_WDT)
#use rs232(baud=250000, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=9, ERRORS, BRGH1OK,stream=DMX512_STREAM)
i defined two streams for rs232 (see above). at certain moments i need to change the speed of the second stream at runtime and change it back. is the a way to do this or do i need to define a third stream
Original Post ID: 13963
Neutone
Re: rs232 streams
PostPosted: Thu Apr 24, 2003 7:37 am     Reply with quote
:=Hello foolks,
:=can someone help me with the following problem :
:=#use rs232(baud=4800, xmit=PIN_D5, rcv=PIN_D4, stream=NMEA_STREAM, RESTART_WDT)
:=#use rs232(baud=250000, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=9, ERRORS, BRGH1OK,stream=DMX512_STREAM)
:=i defined two streams for rs232 (see above). at certain moments i need to change the speed of the second stream at runtime and change it back. is the a way to do this or do i need to define a third stream
Original Post ID: 13964
Neutone
Re: rs232 streams
PostPosted: Thu Apr 24, 2003 7:39 am     Reply with quote
:=Hello foolks,
The readme.txt file has information on this. It is a feature that has been implimented since the last release of the manual.
Original Post ID: 13965
