RS-232 missing characters
Forest
PostPosted: Sun Apr 20, 2003 8:07 pm     Reply with quote
Anyone know why I always miss the last two characters off string printed to any terminal program??
Am using very minimal program to printf across rs-232. When i use the internal SCI Pins C6 and C7 the last two characters don't print. Works OK when i use Pins_A0 & A1 or when I put a while loop after the printf eg.
putc( getc()+1);
Am reasonably new to C and PICs - probably something I haven't spotted.
#include <16F877.h>
#fuses hs,nowdt,noprotect,noput,nowrt,nolvp,nobrownout
main() {
printf("\r\nRead or Write: ");
printf("start");
Original Post ID: 13849
Re: RS-232 missing characters
PostPosted: Sun Apr 20, 2003 8:54 pm     Reply with quote
:=Anyone know why I always miss the last two characters off string printed to any terminal program??
<a href="http://www.pic-c.com/forum/general/posts/12268.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12268.html</a>
Original Post ID: 13850
Dave Yeatman
The CCS compiler automatically puts a Sleep statement at the end of your code and the program is getting there before the USART has a chance to send the data. Add the following to the end of your main block and it should fix your problem:
while (TRUE) {}
Dave
:=Am using very minimal program to printf across rs-232. When i use the internal SCI Pins C6 and C7 the last two characters don't print. Works OK when i use Pins_A0 & A1 or when I put a while loop after the printf eg.
:= while(TRUE)
:= putc( getc()+1);
:=Am reasonably new to C and PICs - probably something I haven't spotted.
:=#include <16F877.h>
:=#fuses hs,nowdt,noprotect,noput,nowrt,nolvp,nobrownout
:=#use delay(clock=4000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=main() {
:= printf("\r\nRead or Write: ");
:= printf("start");
Original Post ID: 13851
