FYI: printing int32 undocumented
david smith
PostPosted: Sun Apr 20, 2003 3:46 pm     Reply with quote
I want to keep a running total that may exceed 32k. CCS manual indicates a valid type of INT32 (4byte integer).
In a printf(), \%Lu is for 16bit unsigned.
As it turns out, it works for int32 signed and unsigned.
int32 count;
count = 79999;
printf("\%08Lu",count); OR
signed int32 count;
count = -85000;
printf("\%\%08Ld",count);
Original Post ID: 13837
Kenny
Re: FYI: printing int32 undocumented
PostPosted: Sun Apr 20, 2003 4:20 pm     Reply with quote
:=I want to keep a running total that may exceed 32k. CCS manual indicates a valid type of INT32 (4byte integer).
:=In a printf(), \%Lu is for 16bit unsigned.
:=As it turns out, it works for int32 signed and unsigned.
:=int32 count;
:=count = 79999;
:=printf("\%08Lu",count); OR
:=signed int32 count;
:=count = -85000;
:=printf("\%\%08Ld",count);
Perhaps you have an early version of the manual.
It's in the manual I have dated September 2002, also in the one dated July 2001, and in the on screen help of IDE ver. 3.28 (PCM ver. 3.150):
"Longs in the printf may be 16 or 32 bit"
Regards
Kenny
Original Post ID: 13839
david smith
PostPosted: Sun Apr 20, 2003 10:30 pm     Reply with quote
:=Perhaps you have an early version of the manual.
Yup, mine's earlier, though the compiler is new.
Thanks.
Original Post ID: 13852
