USB testing ex_usb_serial.c with Proteus
jmorfeos
PostPosted: Wed Sep 30, 2009 4:01 pm     Reply with quote
Hi, I'm for a couple of days trying to make my USB project with several Internet examples like PicUSB from J1M and I have always the same problem. When I try the hex file with these examples in Proteus it works fine but when I compile the project myself it doesn't work.
Finally I tried this example ex_usb_serial.c from CCS with PCWHD 4.093 and Proteus 7.4 SP3 for simulation. I took the c file and copied it to a new folder and make a new project with this file, changed __USB_PIC_EXPLORER16__ to 0 then compiled. I try the hex and COF file and it doesn't work. I make a copy of the result with the virtual terminal to see where it stops here.
All three leds are ON but I see the program step by step and he turns it off but the simulator don't do it!!!
The circuit is here.
Please help!!! Confused
I try a lot of usb_cdc.h and other libraries changes and it's still not working.
What could it be??? Could it be a change in the library of new 4 CCS version??
Sorry for my spanglish
I've forget, here i put the compiler output with some warnings and fuses...
jmorfeos
PostPosted: Fri Oct 02, 2009 8:13 am     Reply with quote
I made a test with CCS version 3.249 and it works fine!!! What could be the diferrence between versions??? Please somebody Help !!!! Shocked
gmua
Re: USB testing ex_usb_serial.c with Proteus
PostPosted: Mon Feb 07, 2011 5:06 pm     Reply with quote
Sorry to bring up an old post, but, Did you ever get it to work with version 4.093? I am using version 4.106 and it doesn't work either.
Thanks.
