Microchip Mtouch capacitive touch sensor
Fram_fr
PostPosted: Mon Dec 08, 2008 6:20 pm     Reply with quote
Hi all,
inspired by Microchip Mtouch app. notes and especially AN1171 and Nuts&volt technical paper (june 2008), I start to write a driver for the Build-in Mtouch µC 16F722, 16F723 and 16F726.
So, here is the code and the questions on the bottom Wink
// Filename:  Cap_touch726.c
// Purpose: Illustrate the use of the Capacitive Sensing Module
//  This program scans 8 pads on a PCB. Each pad is sensed by the Capacitive
//  Sensing Module at a fixed interval.  The frequency of each pad at rest is averaged.l
//  When a pad is touched, the frequency on the Cap. sensing module changes due to the
//  extra capacitance from the finger.  The change in frequency is noted and the LEDs
//  light up to indicate which button was pressed.
#include <16F726.h>
#fuses INTRC,NOWDT,NOPROTECT,NOLVP,PUT,NODEBUG,BROWNOUT
#define INT_TIMER1G                0x8C80
//*********************register definitions ************************
#byte OSCCON = 0x90
#byte OPTION = 0x81
#byte T1CON = 0x10
#byte T1GCON = 0x8f
#byte CPSCON0 = 0x108
#byte INTCON = 0x0b
#byte CPSCON1 = 0x109
#byte PIE1 = 0x8c
#byte PIR1 = 0x0c
#byte TMR1L = 0x0e
#byte TMR1H = 0x0f
// T1CON bits
#bit TMR1ON = T1CON.0
// INTCON bits
#bit GIE = INTCON.7
#bit PEIE = INTCON.6
#bit T0IE = INTCON.5
#bit T0IF = INTCON.2
// PIE1 bits
#bit TMR1GIE = PIE1.7
// PIR1 bits
#bit TMR1GIF = PIR1.7
//   KEYPAD BIT STRUCTURE
//      Used for bit indicators for button presses
struct capacitive_keypad {
      char PAD0 : 1;
      char PAD1 : 1;
      char PAD2 : 1;
      char PAD3 : 1;
      char PAD4 : 1;
      char PAD5 : 1;
      char PAD6 : 1;
      char PAD7 : 1;
   } keypad;
//   SENSOR COUNT DEFINITIONS
#define   MAXSENSORS          8
#define   NUM_AVG_PASSES      3
#define   NUM_STAB_PASSES     5
#define   HYSTERESIS_VALUE    30
//*   I/O DEFINITIONS
#define CONFIG0         PIN_A6
#define CONFIG1         PIN_A7
#define INT_MTOUCH      PIN_A3
//*   SRAM DEFINITIONS
unsigned int   timer1_val[MAXSENSORS];
unsigned int   timer1_raw[MAXSENSORS];
unsigned int   btn_average[MAXSENSORS];
unsigned int   trip_val[MAXSENSORS];
char stabilize_pass;
char average_pass;
char btn_pressed;
char sensor_index;
#define   OUTPUT0         PIN_C0
#define   OUTPUT1         PIN_C1
#define   OUTPUT2         PIN_C2
#define   OUTPUT3         PIN_C3
#define   OUTPUT4         PIN_C4
#define   OUTPUT5         PIN_C5
#define   OUTPUT6         PIN_C6
#define   OUTPUT7         PIN_C7
//*   FUNCTION PROTOTYPES
void init(void);
void interrupt_sensor(void);
void reset_timer1(void);
void select_next_sensor(void);
//*   INITIALIZE FUNCTION
void init()
   char x;
   OSCCON = 0x30;   //16 MHz PLLEN
//* Initialize for timers (Timer0 time base)
   OPTION = 0b11000101;          // Timer0 INIT CLK ON FOSC/4
   T0IF = 0;                     // Clear Timer0 interrupt flag
   T0IE = 1;                     // enable Timer0 interrupt
   T1CON  = 0b01000101;          // Timer1 enable, system clock, 1:1 prescale,
   T1GCON = 0b11100001;          // Timer1 gate init
//*   SETUP CAP SENSE MODULE
   CPSCON0 = 0b10001100;         // Cap Sense control settings
   CPSCON1 = 0;                  // init to channel select = 0 (4 LSb's)
//*   SETUP CAP SENSE VARIABLES
   stabilize_pass = NUM_STAB_PASSES;
   average_pass = NUM_AVG_PASSES;
   trip_val[0] = 120;
   trip_val[1] = 120;
   trip_val[2] = 120;
   trip_val[3] = 120;
   trip_val[4] = 120;
   trip_val[5] = 120;
   trip_val[6] = 120;
   trip_val[7] = 120;
   for(x = 0; x < MAXSENSORS; x++)
      btn_average[x] = 0;
//* Gate Setup
   TMR1GIF   = 0;                  // clear gate interrup flag
   TMR1GIE   = 1;                  // enable gate interrup
   PEIE      = 1;                  // enable peripheral intpts
   GIE       = 1;                  // enable global intpts
//* Initialize for interrup pin output
   output_low(INT_MTOUCH);        // clear output interrupt pin
// ISR() Interrupt Service Routine
// Reads values of TMR1 corresponding to each button/sensor
// and makes decision if button/sensor has been touched.
#int_timer0                      // Timer0 Interrupt
void timer0_isr()
   if (T0IF==1)
         T0IF = 0;               // clear interrup flag
#int_timer1g                     // Timer1 Gate Interrupt
void timer1_gate_isr()
   if(TMR1GIF==1)
      TMR1GIF = 0;               // clear interrup flag
      TMR1ON = 0;                // TIMER1 off
      timer1_val[sensor_index] = make16(TMR1H,TMR1L);
      timer1_raw[sensor_index] = timer1_val[sensor_index] * 16;
      //stabilize the btn_average value
      if(stabilize_pass > 0x00)
         stabilize_pass--;
         btn_average[sensor_index] = timer1_raw[sensor_index];
         reset_timer1();
         if((stabilize_pass == 0) && (sensor_index < (MAXSENSORS - 1)))
            select_next_sensor();
         //check for button pressed
         if(timer1_raw[sensor_index] < (btn_average[sensor_index] - trip_val[sensor_index]))
            if(!(keypad.PAD0 || keypad.PAD1 || keypad.PAD2 ||
                keypad.PAD3 || keypad.PAD4 || keypad.PAD5 ||
                keypad.PAD6 || keypad.PAD7 ))
                   output_high(INT_MTOUCH);
                   switch(sensor_index)
                      case 0:   keypad.PAD0 = 1;   break;
                      case 1:   keypad.PAD1 = 1;   break;
                      case 2:   keypad.PAD2 = 1;   break;
                      case 3:   keypad.PAD3 = 1;   break;
                      case 4:   keypad.PAD4 = 1;   break;
                      case 5:   keypad.PAD5 = 1;   break;
                      case 6:   keypad.PAD6 = 1;   break;
                      case 7:   keypad.PAD7 = 1;   break;
         else if(timer1_raw[sensor_index] > (btn_average[sensor_index] - trip_val[sensor_index])+ HYSTERESIS_VALUE)
                      case 0:   keypad.PAD0 = 0;   break;
                      case 1:   keypad.PAD1 = 0;   break;
                      case 2:   keypad.PAD2 = 0;   break;
                      case 3:   keypad.PAD3 = 0;   break;
                      case 4:   keypad.PAD4 = 0;   break;
                      case 5:   keypad.PAD5 = 0;   break;
                      case 6:   keypad.PAD6 = 0;   break;
                      case 7:   keypad.PAD7 = 0;   break;
         if(timer1_raw[sensor_index] > (btn_average[sensor_index]))
            btn_average[sensor_index] = btn_average[sensor_index] + (timer1_val[sensor_index] - (btn_average[sensor_index] / 16));
         //compute average
         average_pass--;
         if(average_pass == 0)
         reset_timer1();
//*   TIMER1 RESET FUNCTION - Reset and restart timer 1
void reset_timer1()
   TMR1L   = 0;   // clear TIMER1 low byte
   TMR1H   = 0;   // clear TIMER1 high byte
   TMR1ON  = 1;   // start TIMER1
//*   SELECT NEXT CPS CHANNEL
void select_next_sensor()
   sensor_index++;            // cycle index state 0-7 w/rollover
   if(sensor_index >= MAXSENSORS)
      sensor_index = 0;
   CPSCON1 = sensor_index;    // Select external pin CPS0..CPS7
//*     MAIN FUNCTION
   Init();
   sensor_index = 0;          // Start program ready to scan first channel
   while(true)                // Loop forever
      // React to button presses in application main-loop
      if (keypad.PAD0)
            output_high(OUTPUT0);
         } else {
            output_low(OUTPUT0);
      if (keypad.PAD1)
            output_high(OUTPUT1);
         } else {
            output_low(OUTPUT1);
      if (keypad.PAD2)
            output_high(OUTPUT2);
         } else {
            output_low(OUTPUT2);
      if (keypad.PAD3)
            output_high(OUTPUT3);
         } else {
            output_low(OUTPUT3);
      if (keypad.PAD4)
            output_high(OUTPUT4);
         } else {
            output_low(OUTPUT4);
      if (keypad.PAD5)
            output_high(OUTPUT5);
         } else {
            output_low(OUTPUT5);
      if (keypad.PAD6)
            output_high(OUTPUT6);
         } else {
            output_low(OUTPUT6);
      if (keypad.PAD7)
            output_high(OUTPUT7);
         } else {
            output_low(OUTPUT7);
and the questions:
/ I need to configure OPTION2 register to choose VCAP pin (in my case, VCAP on RA0) but Vcap configuration should be a fuse.
How to add a fuse on CCS which doesn't exist?
/ How to add an interrupt on CCS device.h file? Because
and
#int_timer1g
don't work...
I'm not an expert. So, don't hesitate to add comments on my code.
Franck
PostPosted: Mon Dec 08, 2008 7:22 pm     Reply with quote
Vs. 4.083 has fuses for VCAP. Here is part of the .H file:
//////// Standard Header file for the PIC16F726 device ////////////////
//////// Fuses: VCAP_A0, VCAP_A5, VCAP_A6, NOVCAP,NOBROWNOUT
I don't see an entry for INT_TIMER1G in the .H file for vs. 4.083.
This thread has an example of using #int_default as a work-around.
However, read Ttelmah's comment.
http://www.ccsinfo.com/forum/viewtopic.php?p=106973
Another possible work-around is, if you have the IDE version of the
compiler, then you could edit the Device data (using the Device Editor)
and add the new interrupt. I don't have the IDE version, so I can't
test it for you. Someone mentioned that the Device Editor has a button
to generate a new, updated .H file that will incorporate your changes,
once you have made them.
Again, if your version doesn't have the VCAP fuses, you could use the
Device Editor to add them.
Fram_fr
PostPosted: Wed Dec 10, 2008 5:46 am     Reply with quote
PCM programmer,
Thank you very much for your answer.
I updated my CCS release and it's now OK about VCAP fuse.
About interrupt, I will check your solution using #int_default.
Franck Wink
Fram_fr
PostPosted: Thu Dec 11, 2008 6:05 pm     Reply with quote
Here is a code that should be work now! (not tested on real hardware)
It is possible to configure output level when a pad is touched:
- high output level when OUT_POLARITY pin is set to GND.(standard)
- low output level when OUT_POLARITY pin is set to VCC.(invert)
INT_MTOUCH is set to VCC when a pad is touched.(interrupt pin for main µC)
2 others pins (config0 and config1) are for incoming code (I2C and SPI possibilities...)
Check I/O DEF and pic datasheet for hardware config.
More coming next with I2C and SPI possibilities.
// Filename:  Mtouch722_723_726.h
// Purpose: Registers and Defines for Mtouch Cap_Sense module
#byte OSCCON = 0x90
#byte OPTION = 0x81
#byte T1CON = 0x10
#byte T1GCON = 0x8f
#byte INTCON = 0x0b
#byte PIE1 = 0x8c
#byte PIR1 = 0x0c
#byte TMR1L = 0x0e
#byte TMR1H = 0x0f
// T1CON bits
// INTCON bits
#bit GIE = INTCON.7
// PIE1 bits
// PIR1 bits
      char PAD0 : 1;
      char PAD1 : 1;
      char PAD2 : 1;
      char PAD3 : 1;
      char PAD4 : 1;
      char PAD5 : 1;
      char PAD6 : 1;
      char PAD7 : 1;
   } keypad;
#locate keypad=0x20
//*   I/O DEFINITIONS
#define CONFIG0            PIN_A6   // optionnal config. pin
#define CONFIG1            PIN_A7   // optionnal config. pin
#define INT_MTOUCH         PIN_A3   // interrupt pin output
#define OUT_POLARITY       PIN_A2   // output polarity configuration
// Filename:  Mtouch722_723_726.c
// It is possible to configure output level when a pad is touched:
// - high output level when OUT_POLARITY pin is set to GND.(standard)
// - low output level when OUT_POLARITY pin is set to VCC.(invert)
// INT_MTOUCH is set to VCC when a pad is touched.(interrupt pin for main µC)
// Check I/O DEF. and pic datasheet for hardware config.
//!#include <16F722.h>
//!#include <16F723.h>
#include <16F726.h>
#include <Mtouch722_723_726.h>
#FUSES INTRC_IO                  //Internal RC Osc, no CLKOUT
#FUSES VCAPA0                    //VCAP on pin A0
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES NOPROTECT                 //Code not protected from reading
#FUSES PLLEN                     //Enable PLL
#FUSES NODEBUG                   //No Debug mode for ICD
#FUSES MCLR                      //Master Clear pin enabled
#FUSES NOBROWNOUT                //No brownout reset
#FUSES NOPUT                     //No Power Up Timer
char average_pass;
char sensor_index;
void init(void);
void timers_isr(void);
void init()
   char x;
   OSCCON = 0x30;   //16 MHz with PLLEN
   trip_val[0] = 120;
   trip_val[1] = 120;
   trip_val[2] = 120;
   trip_val[3] = 120;
   trip_val[4] = 120;
   trip_val[5] = 120;
   trip_val[6] = 120;
   trip_val[7] = 120;
      btn_average[x] = 0;
//* Gate Setup
//* Initialize for pins output
   if (!input(OUT_POLARITY))        // polarity pin is set to 0
         output_low(OUTPUT0);       // set output pin low
         output_low(OUTPUT1);       // set output pin low
         output_low(OUTPUT2);       // set output pin low
         output_low(OUTPUT3);       // set output pin low
         output_low(OUTPUT4);       // set output pin low
         output_low(OUTPUT5);       // set output pin low
         output_low(OUTPUT6);       // set output pin low
         output_low(OUTPUT7);       // set output pin low
    if (input(OUT_POLARITY))        // polarity pin is set to 1
         output_high(OUTPUT0);      // set output pin high
         output_high(OUTPUT1);      // set output pin high
         output_high(OUTPUT2);      // set output pin high
         output_high(OUTPUT3);      // set output pin high
         output_high(OUTPUT4);      // set output pin high
         output_high(OUTPUT5);      // set output pin high
         output_high(OUTPUT6);      // set output pin high
         output_high(OUTPUT7);      // set output pin high
      btn_average[x] = 0;
#INT_DEFAULT                     // Interrupt
void timers_isr()
   if (T0IF==1)                  // Timer0 Interrupt
   if(TMR1GIF==1)                // Timer1 gate Interrupt
         stabilize_pass--;
         reset_timer1();
         //compute average
         average_pass--;
         reset_timer1();
void reset_timer1()
      sensor_index = 0;
//*     MAIN FUNCTION
   Init();
   while(true)
         if (!input(OUT_POLARITY))        // default polarity pin is set to 0
               if (keypad.PAD0)
                  } else {
               if (keypad.PAD1)
                  } else {
               if (keypad.PAD2)
                  } else {
               if (keypad.PAD3)
                  } else {
               if (keypad.PAD4)
                  } else {
               if (keypad.PAD5)
                  } else {
               if (keypad.PAD6)
                  } else {
               if (keypad.PAD7)
                  } else {
         if (input(OUT_POLARITY))        // default polarity pin is set to 1
               if (keypad.PAD0)
                  } else {
               if (keypad.PAD1)
                  } else {
               if (keypad.PAD2)
                  } else {
               if (keypad.PAD3)
                  } else {
               if (keypad.PAD4)
                  } else {
               if (keypad.PAD5)
                  } else {
               if (keypad.PAD6)
                  } else {
               if (keypad.PAD7)
                  } else {
maheshkuruganti
MTouch Capacitive Sensor
PostPosted: Mon May 11, 2009 2:45 am     Reply with quote
I know this is a inactive thread but can you please tell me if the above code works and also if there is a circuit or pcb which I can look at for the above code to be used.Thanks
Fram_fr
PostPosted: Thu May 21, 2009 4:53 pm     Reply with quote
Sorry, I've no test this code because no hardware for the moment.
The design of the pcb for the capacitive touch is done but not manufactured.
Regards,
Franck
Krunal Thummar
Re: Microchip Mtouch capacitive touch sensor
PostPosted: Wed Aug 02, 2017 2:33 am     Reply with quote
To : Fram_fr,
From : krunal_c_thummar@yahoo.com // Gujarat-India //
Dear Sir,
Based on your code, I have implemented this code in 'C' and with microchip PIC16F722A controller. It is working absolutely 100% fine.
//   PIC16F722A Capsense Module Test
//   As frequency is reduced, counting of Timer1 counts is also reduced.
//   RB0:RB5,RA4:RA5 as touch pads (Analog inputs)
//   PORTC as LED outputs (Digital outputs)
#include<pic.h>
#include<htc.h>
#include<pic16f722a.h>
__CONFIG(FOSC_INTOSCIO & WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_OFF & BOREN_OFF & BORV_19 & PLLEN_ON);
__CONFIG(VCAPEN_DIS);
#define   MAXSENSORS         8         //   8
#define   NUM_AVG_PASSES      3          //   3
#define   NUM_STAB_PASSES      5         //   5
#define   HYSTERESIS_VALUE   30          //   30
#define   LED_0   RC0
#define   LED_1   RC1
#define   LED_2   RC2
#define   LED_3   RC3
#define   LED_4   RC4
#define   LED_5   RC5
#define   LED_6   RC6
#define   LED_7   RC7
#define output_default_io_polarity      1   //   default io = 1. When pad is touched, output io = 0.
//#define output_default_io_polarity   0   //   default io = 0. When pad is touched, output io = 1.
unsigned char stabilize_pass = 0;
unsigned char average_pass = 0;
unsigned char btn_pressed = 0;
unsigned char sensor_index = 0;
unsigned char x = 0;
unsigned char button_0 = 0,button_1 = 0,button_2 = 0,button_3 = 0;
unsigned char button_4 = 0,button_5 = 0,button_6 = 0,button_7 = 0;
//   TIMER1 RESET FUNCTION - Reset and restart timer 1
void reset_timer1()
   TMR1   = 0;   //   clear TIMER1 resister
//   SELECT NEXT CPS CHANNEL
      sensor_index = 0;
   CPSCON1 = sensor_index;         //   Select external pin CPS0.....CPS7
static void interrupt isr(void)         //   Timer0 Interrupt
   if(T0IF == 1)
      T0IF = 0;                  //   clear interrupt flag
   if(TMR1GIF == 1)
      TMR1GIF   = 0;               //   clear interrupt flag
      timer1_val[sensor_index] = TMR1;
      if(stabilize_pass < NUM_STAB_PASSES)
         stabilize_pass++;
         reset_timer1();
         if((stabilize_pass == NUM_STAB_PASSES) && (sensor_index < (MAXSENSORS - 1)))
            stabilize_pass = 0;
               case 0:   button_0=1;   break;   //   button_0 is touched
               case 1:   button_1=1;   break;
               case 2:   button_2=1;   break;
               case 3: button_3=1;   break;
               case 4: button_4=1;   break;
               case 5: button_5=1;   break;
               case 6: button_6=1;   break;
               case 7: button_7=1;   break;
               case 0:   button_0=0;   break;   //   button_0 is not touched
               case 1:   button_1=0;   break;
               case 2:   button_2=0;   break;
               case 3: button_3=0;   break;
               case 4: button_4=0;   break;
               case 5: button_5=0;   break;
               case 6: button_6=0;   break;
               case 7: button_7=0;   break;
         //compute average
         average_pass++;
         if(average_pass == NUM_AVG_PASSES)
            average_pass = 0;
         reset_timer1();
//   MAIN FUNCTION
   OSCCON = 0b00110000;         //   16MHz Internal Oscillator
   ANSELA = 0b00110000;         //   CPS6:CPS7 as analog input
   ANSELB = 0b00111111;         //   CPS0:CPS5 as analog input
   TRISA = 0b00110000;            //   RA4:RA5 as input
   TRISB = 0b00111111;            //   RB0:RB5 as input
   TRISC = 0;                 //   PORTC as digital output
   //   Initialize for timers (Timer0 time base 4ms)
   OPTION_REG = 0b11000101;      //   Timer0 INIT CLK ON FOSC/4
   //   SETUP TIMER1
   T1CON   = 0b11000101;         //   Clock source is Capacitive Sensing Oscillator, 1:1 prescale, Timer1 enable,
   T1GCON    = 0b11100001;         //   Timer1 gate init with Timer0
   TMR1GIF = 0;               //   clear gate interrupt flag
   TMR1GIE = 1;               //   enable gate interrupt
   PEIE = 1;                  //   enable peripheral interrupts
   GIE    = 1;                  //   enable global interrupts
   //   SETUP CAP SENSE MODULE
   //   below values set sensitivity, less value effects more sensitive touch pad
   trip_val[0] = 120;            //   tripping value for pad-0
   trip_val[1] = 120;             //   tripping value for pad-1
   trip_val[2] = 120;             //   tripping value for pad-2
   trip_val[3] = 120;             //   tripping value for pad-3
   trip_val[4] = 120;             //   tripping value for pad-4
   trip_val[5] = 120;             //   tripping value for pad-5
   trip_val[6] = 120;             //   tripping value for pad-6
   trip_val[7] = 120;            //   tripping value for pad-7
   for(x=0;x<MAXSENSORS;x++)      //   initially make all avarage values zero
   btn_average[x] = 0;
   if(output_default_io_polarity==1)   //   make all outputs low or high
      PORTC = 0xFF;
      PORTC = 0x00;
         if(button_0)      //   if pad-0 is touched
            LED_0=0;      //   make op low
            LED_0=1;
         if(button_1)
            LED_1=0;
            LED_1=1;
         if(button_2)
            LED_2=0;
            LED_2=1;
         if(button_3)
            LED_3=0;
            LED_3=1;
         if(button_4)
            LED_4=0;
            LED_4=1;
         if(button_5)
            LED_5=0;
            LED_5=1;
         if(button_6)
            LED_6=0;
            LED_6=1;
         if(button_7)
            LED_7=0;
            LED_7=1;
      else if(output_default_io_polarity==0)
            LED_0=1;      //   make op high
            LED_0=0;
         if(button_1)
            LED_1=1;
            LED_1=0;
         if(button_2)
            LED_2=1;
            LED_2=0;
         if(button_3)
            LED_3=1;
            LED_3=0;
         if(button_4)
            LED_4=1;
            LED_4=0;
         if(button_5)
            LED_5=1;
            LED_5=0;
         if(button_6)
            LED_6=1;
            LED_6=0;
         if(button_7)
            LED_7=1;
            LED_7=0;
// krunal_c_thummar@yahoo.com      // Gujarat-India //
