Problem displaying compass bearing on lcd
Gerhard
PostPosted: Sat Sep 06, 2008 4:38 pm     Reply with quote
Hi. I have a HMC6352 honeywell compass conected to a PIC16f886 using i2c. Problem is that the LCD is working and i get correct readout of other variables but when i use the compass i only get garbage.
Please advice if i made a common mistake.
#include <16F886.H>
#use delay(clock=20000000)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
#include <Flex_LCD420.c>
#define HMC6352_I2C_WRITE_ADDRESS 0x42
#define HMC6352_I2C_READ_ADDRESS  0x43
#define HMC6352_GET_DATA_COMMAND 0x41
int16 heading;
void setup()
 //    setup_timer_0(RTCC_INTERNAL | RTCC_DIV_32);
  //   enable_interrupts(INT_TIMER0);
 //    enable_interrupts(global);
 //    set_rtcc (100);
int16 HMC6352_read_heading(void);
void clearLCD();
   setup();
   clearLCD();
   heading = HMC6352_read_heading();
   heading=heading/100;
   lcd_gotoxy(1,1);
   printf(lcd_putc, "heading");
   lcd_gotoxy(1,2);
   printf(lcd_putc,"%lu", heading);
   delay_ms(1000);  }
int8 lsb;
int8 msb;
i2c_start();
i2c_write(HMC6352_I2C_WRITE_ADDRESS);
i2c_write(HMC6352_GET_DATA_COMMAND);
i2c_stop();
delay_ms(7);
i2c_start();
i2c_write(HMC6352_I2C_READ_ADDRESS);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
return((int16)msb | ((int16)lsb << 8));
void clearLCD()
    printf(lcd_putc, "\f");
RayJones
PostPosted: Sat Sep 06, 2008 6:23 pm     Reply with quote
First obvious thing is you've assembled the 16 bit integer incorrectly.
You have
This should be
return((int16)lsb | ((int16)msb << 8));
Ray
Gerhard
PostPosted: Sat Sep 06, 2008 6:57 pm     Reply with quote
Thanks.
Between you and PCM programmer a driver has been written perfectly.
It should be posted in the Code library so it could help others in future.
Works perfectly
andrewg
PostPosted: Sat Sep 06, 2008 10:45 pm     Reply with quote
Instead of
I prefer to use
return make16(msb, lsb);
which is a teeny bit more efficient.
Andrew
RayJones
PostPosted: Sun Sep 07, 2008 12:43 am     Reply with quote
Granted, but even more efficient using standard C functionality would be:
typedef union {
  int16 word;
  struct {
    int8 lsb;
    int8 msb;
  } bytes;
} Val16 ;
int16 example1()
  Val16 heading;
  heading.bytes.msb = i2c_read();
  heading.bytes.lsb = i2c_read(0);
  return heading.word;
ie. the compiler directly places the values in the memory locations for the 16 bit word and no further fiddling is required Very Happy
Even more efficient, utilising some of the C++ functionality in the CCS compiler, try this:
void example2(Val16& heading)
Once again, this puts the values directly into a 16 bit value, but even better than that, the pass by reference puts these writes smack bang into the calling routine's 16 bit value. Laughing
Sorry, I got bored and had to have a play about. Wink
Cheers, Ray
RayJones
PostPosted: Sun Sep 07, 2008 12:49 am     Reply with quote
Oh yeah, for OP's benefit, the way you'd call these are:
main() {
  int16 heading;
  heading = example1();
  example2(heading);
All tested on my copy of CCS. Smile
Cheers, Ray
PostPosted: Sun Sep 07, 2008 2:51 am     Reply with quote
Yes.
The compiler is pretty efficient in this area, and will optimise to very nearly the same code for each approach to combining the bytes, but the union approach, is 'standard C', and will work (with caveats about byte order), on any C, while the 'make16' function is CCS specific.
