40Mhz on 18F458
Thomas R
40Mhz on 18F458
PostPosted: Wed Mar 26, 2003 6:32 am     Reply with quote
I need some help on connecting a 40Mhz xtal to a pic18F458
Is there someone that has a tip on the cap. size to use
my xtal data say that it has to haw a 30pF load
the book from Microchip only gives eks. Up to 25Mhz..
try to give my design 2*15pF…But it seems to be unstable
any ideas ?
And NO I do not want to use the PLL whit a 10Mhz
Best Regards
Thomas
Original Post ID: 13080
john cutler
Re: 40Mhz on 18F458
PostPosted: Wed Mar 26, 2003 9:50 am     Reply with quote
I just looked at the pdf, and it says a 0 - 40mhz external clock is ok - are you sure a crysta; will work that fast without the pll?
=I need some help on connecting a 40Mhz xtal to a pic18F458
:=Is there someone that has a tip on the cap. size to use
:=my xtal data say that it has to haw a 30pF load
:=the book from Microchip only gives eks. Up to 25Mhz..
:=try to give my design 2*15pF?But it seems to be unstable
:=any ideas ?
:=And NO I do not want to use the PLL whit a 10Mhz
:=Best Regards
:=Thomas
Original Post ID: 13090
Hans Wedemeyer
Re: 40Mhz on 18F458
PostPosted: Wed Mar 26, 2003 6:31 pm     Reply with quote
I wonder why you object to using the PLL ?
I have many PIC18 designs using the PLL at 40 and 48MHz they are very stable.
Original Post ID: 13113
Thomas R
Re: 40Mhz on 18F458
PostPosted: Thu Mar 27, 2003 4:04 am     Reply with quote
I want to use timer1 whit 40Mhz clock direct so that the resolusion is 25 -09 seconds
and it looks as if i use the pll it is divede by 4 so that it is back to 10Mhz
and i am trying to avoide to use 2 xtals
Thomas
:=:=And NO I do not want to use the PLL whit a 10Mhz
:=I wonder why you object to using the PLL ?
:=I have many PIC18 designs using the PLL at 40 and 48MHz they are very stable.
Original Post ID: 13127
R.J.Hamlett
Re: 40Mhz on 18F458
PostPosted: Thu Mar 27, 2003 5:10 am     Reply with quote
:=I want to use timer1 whit 40Mhz clock direct so that the resolusion is 25 -09 seconds
:=and it looks as if i use the pll it is divede by 4 so that it is back to 10Mhz
:=and i am trying to avoide to use 2 xtals
:=Thomas
So you have the OSC2 pin, also connected to RC0, and are setting the timer to use the external clock, asynchronoulsy, without a prescaler?.
Your first problem is that the internal crystal oscillator, is _not_ specified to run this fast. To run with a 40MHz source, requires the use of an external oscillator module, and selecting 'EC' as the clock source. Table 27-6, in the data sheet shows this. The maximum oscillator frequency shown with the HS oscillator, is 25MHz.
Also you may well have problems with the input to the counter module. The shortest legal clock period for this input (table 27-10), is 60nsec, in asynchronous mode (16.6MHz), or the processor clock frequency+40nsec, in synchronous mode (15.5MHz).
You are trying to go to far beyond the processors spec...
:=:=:=And NO I do not want to use the PLL whit a 10Mhz
:=:=I wonder why you object to using the PLL ?
:=:=I have many PIC18 designs using the PLL at 40 and 48MHz they are very stable.
Original Post ID: 13130
