Fail to program config, lvp
Calamar
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat Mar 22, 2003 10:54 am     Reply with quote
Dears sirs:
I'm having some trougles to program th 16f873 using
the programmer(Hardawre) showed in the page:
<a href="http://www.finitesite.com/d3jsys/" TARGET="_blank">http://www.finitesite.com/d3jsys/</a>
The same page recomend FPP (Flash Pic Programmer, software),
well, please look at the folowing C code, check out the fuses
#include <16F873.h>
#fuses XT, NOPROTECT, NOPUT, NOWDT, BROWNOUT, NOLVP, NOCPD, NOWRT
#byte PORTB=6
#byte PORTA=5
#byte PORTC=7
#use standard_io ( a )
#use standard_io ( b )
#use standard_io ( c )
main() {
setup_adc(ADC_OFF);
set_tris_a(0);
set_tris_b(0);
set_tris_c(0);
PORTA=0;
PORTB=0;
PORTC=255;
when I try to programmer the pic using FPP, it write the program code
correctly but doen't write the fuse (Fail to program config)
changing NOLVP to LVP in the fuses the confing reach write correctly,
but the pics doesn't work correctly, i have read that it is because
I must set NOLVP, but the fpp doesn't let me do it.
Original Post ID: 12956
Best Regards
Daniel H. Sagarra
La Plata (Argentina)
Re: Fail to program config, lvp
PostPosted: Sat Mar 22, 2003 12:13 pm     Reply with quote
:=Dears sirs:
:=I'm having some trougles to program th 16f873 using
:=the programmer(Hardawre) showed in the page:
:= <a href="http://www.finitesite.com/d3jsys/" TARGET="_blank"> <a href="http://www.finitesite.com/d3jsys/" TARGET="_blank">http://www.finitesite.com/d3jsys/</a></a>
:=The same page recomend FPP (Flash Pic Programmer, software),
:=well, please look at the folowing C code, check out the fuses
:=#include <16F873.h>
:=#fuses XT, NOPROTECT, NOPUT, NOWDT, BROWNOUT, NOLVP, NOCPD, NOWRT
:=#byte PORTB=6
:=#byte PORTA=5
:=#byte PORTC=7
:=#use standard_io ( a )
:=#use standard_io ( b )
:=#use standard_io ( c )
:=main() {
:= setup_adc(ADC_OFF);
:= set_tris_a(0);
:= set_tris_b(0);
:= set_tris_c(0);
:=while(1)
:= PORTA=0;
:= PORTB=0;
:= PORTC=255;
:=when I try to programmer the pic using FPP, it write the program code
:=correctly but doen't write the fuse (Fail to program config)
:=changing NOLVP to LVP in the fuses the confing reach write correctly,
:=but the pics doesn't work correctly, i have read that it is because
:=I must set NOLVP, but the fpp doesn't let me do it.
That programmer uses Low Voltage Programming. You should
set the #fuse to LVP, to get rid of your error message.
The reason you get an error message is because the LVP
fuse cannot be changed when using a LVP programmer. The
"TLVP" programmer, which you are using, is a LVP programmer.
So, that error message is correct. But that's good. You
want to use LVP mode with that programmer.
This is explained in section 12.18 of the 16F87x data sheet.
Also, that section has some warnings about not using pin B3,
when you have LVP mode enabled. You should read that section
carefully and follow the warnings. If you don't, your program
will "lock-up" and not work.
When you see on this board some warnings to use "NOLVP",
that's for normal programmers. It's a warning for people
who use the PicStart-Plus and the Warp-13a, etc. Most
people use that type of programmer. But that warning does
not apply to you since you're using the TLVP programmer.
Original Post ID: 12958
Calamar
PostPosted: Sat Mar 22, 2003 5:11 pm     Reply with quote
I have been reading the 1.18 section and I have some questions
can I disable LPV once the program is running ??
if I can after that I colud program the pic again ??
if I can't, where should the RB3 be conected when the
program is running.. y think so I am having noise problems
because the program stop when y write in RB2...
Original Post ID: 12964
Best Regards
Daniel H. Sagarra
PostPosted: Sat Mar 22, 2003 10:40 pm     Reply with quote
:=I have been reading the 1.18 section and I have some questions
:=can I disable LPV once the program is running ??
No, you can't. It's a configuration bit, and it can only
be changed during programming. The LVP fuse can only be
changed by a "High Voltage" programmer, such as a PicStart-Plus
or Warp-13a.
:=if I can after that I could program the pic again ??
:=if I can't, where should the RB3 be conected when the
:=program is running.. I think so I am having noise problems
:=because the program stop when y write in RB2...
RB3 should have a pull-down resistor on it. Try using a 10K
resistor, connected to Ground. This will keep it at a low
level, and prevent noise on Pin B3 from locking up the PIC.
The data sheet recommends, that if you enable Port B pull-ups,
you should set pin B3 as an output. In other words, do this:
output_low(PIN_B3); // Set pin B3 low before enabling pullups
port_b_pullups(TRUE);
You only have to set Pin B3 low, if you enable Port B pull-ups.
Many PIC projects do not need to use Port B pull-ups.
Original Post ID: 12966
