Version 4 Comments
Goto page Previous  1, 2, 3, ... 17, 18, 19  Next
treitmey
PostPosted: Tue Jul 25, 2006 4:02 pm     Reply with quote
melstav, go to the email and RE-download the download manager.
That is what fixed my setup.
I am using winXP pro.
melstav
PostPosted: Wed Jul 26, 2006 7:05 am     Reply with quote
I did. Several times. But I kept getting the same version of the file.
On a hunch, I tried downloading via IE instead of Firefox, and I got the updated version. I dunno what the deal was... Maybe Firefox was just feeding me a cached version of the file instead of re-downloading it.
I probably should also have tried exiting from Firefox and reopening it, too.
At any rate, now I've got it installing.
treitmey
PostPosted: Wed Jul 26, 2006 8:20 am     Reply with quote
I did the download with firefox just fine..trying multiple times....
I think its just a timing thing.. you needed to wait for the new file
to be inplace.
PostPosted: Thu Jul 27, 2006 4:48 am     Reply with quote
I think the whole new download system, looks to be the basis of a real 'pain'...
Have tried pulling the download manager twice. Each one behaves the same. Starts downloading, says xxxMB (9.8MB total). Counts up to 39.2MB transferred!. Then tried to run the program updates, and crashes with incorrect file sizes.
Oh well, I'll try again, then report it.
treitmey
PostPosted: Thu Aug 03, 2006 10:21 am     Reply with quote
Is there any way we can get an add/remove comments option in the editor.
I miss highlighting a section of code and having the editor able to put in // in the first col.
PostPosted: Thu Aug 03, 2006 10:31 am     Reply with quote
To install your beta:
1. download the newest version of the download manager from the website
2. Install the download manager into a NEW directory. (ie c:/Program Files/PICC_BetaV4/)
3. Install the beta *.crg files into the SAME new directory as the download manager
4. Run the download manager, and download/install the beta release into the SAME new directory as the download manager
This is what I have seen work. If there are any other issues, please conatct tech support.
There seems to be some problems with some UK downloads. This problem is being looked at and I hope there will be a solution soon.
Storic
PostPosted: Thu Aug 03, 2006 4:44 pm     Reply with quote
Thank you guest, I had done all of the above as you sugested however I still get
PCWH - IDE. . . Request for file size timeout.
Sad
I am from the other side of the globe "Australia"!. Tech support have been contacted on my problem.
the download manager work ok with the examples and the manual (usb, Tcp, manual)
Andrew
What has been learnt if you make the same mistake? Wink
dyeatman
PostPosted: Thu Aug 03, 2006 8:44 pm     Reply with quote
I am in the USA and get the same problem. Anyone able to successfully download and install the update?
treitmey
PostPosted: Fri Aug 04, 2006 7:37 am     Reply with quote
Yes it works. Follow "Guest" advice 2 up from here. I think the trick is the new download manager. Also try different browser.
PostPosted: Fri Aug 04, 2006 8:07 am     Reply with quote
Make sure to use Download Manager version 1.4.25.10. This is the current working version of the Download Manager.
treitmey
PostPosted: Fri Aug 04, 2006 9:41 am     Reply with quote
Using DM-1.4.25.10. It seems like my verstions never change.
current=3.964 local=3.960 and it wants to do a download.
I download, install, reboot.. but the versions don't change and it wants to
download again. Is my registry screwed up, or something?
rajenkins
PostPosted: Fri Aug 04, 2006 11:22 am     Reply with quote
I'm having exactly the same 'PCWH - IDE. . . Request for file size timeout.' problem.
I have tried deleting the directory, re-downloading the download manager (twice with different browsers) & re-installing it but no change..
Robert Jenkins
Worksop, UK.
dyeatman
PostPosted: Fri Aug 04, 2006 2:53 pm     Reply with quote
I have tried to multiple times. I used IE and Firefox to update the Dnld Mgr (cleared the cache each time) but still no go....
PostPosted: Sat Aug 05, 2006 1:47 pm     Reply with quote
Hurrah!.
At least I am not alone!.
I'm either the one, or one of the people mentioned in the UK,who can't get it to download. In my case, I have tried three different computers, half a dozen different downloads of the download manager, and cannot get the program through any route.
I tried a full IP diagnostic on one machine, and it is complaining of an invalid IP packet for one packet inside the data sent by the download manager, which gets rejected by the London geteway server.
I think the new download manager, shows signs of being a real pain...
dyeatman
What's supposed to be working at this point?
PostPosted: Sat Aug 05, 2006 7:49 pm     Reply with quote
Has anyone been able to use the project wizard? It (and a lot of other things like all the documentation stuff) aren't working in mine. I don't know what is supposed to work and what isn't....
BTW: I finally got the download Mgr to work by going back and deleting everything and installing from scratch again. Don't know what wil happen the next time... Smile
Page 2 of 19
