EX_DTMF.C
ljbeng
EX_DTMF.C
PostPosted: Thu Mar 31, 2005 3:19 pm     Reply with quote
I built the R2R network in the example EX_DTMF.C and used the code pretty much unaltered. I did not use the keypad and just send specific tones. The DTMF sounds good on a speaker and I can hold a phone to the speaker and dial my cell number.
When I feed the tone into a CD22204 DTMF tone decoder, it only recognizes tones 7,8,9,*,0. It does not recognize any other tone. I have used these chips before on very noisy DTMF tones and they worked pretty good. Does anyone have any experience with this example or the CD22204? Thanks.
Gabriel Caffese
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Fri Apr 01, 2005 7:18 am     Reply with quote
Check the amplitude of generated signal. Maybe itīs too low to be detected by DTMF decoder.
You could use an LM741, and add same gain to R2Rīs output .
Gabriel.-
Re: EX_DTMF.C
PostPosted: Fri Apr 01, 2005 8:39 am     Reply with quote
Try this, larger amplitude for high frequency tone, smaller amplitude for low frequency tone, and also for 4x4 keypad,
// tone_out.c                                              2002/02/20
                           F_Low F_High  TONE  HM9270_Q4 Q3 Q2 Q1  Hex_from_HM9270
                                                  pin_A3 A2 A1 A0   PORTA & 0x0F
#define  TONE_1    0x01  // 697   1209     1        0    0  0  1          1
#define  TONE_2    0x02  // 697   1336     2        0    0  1  0          2
#define  TONE_3    0x03  // 697   1477     3        0    0  1  1          3
#define  TONE_4    0x04  // 770   1209     4        0    1  0  0          4
#define  TONE_5    0x05  // 770   1336     5        0    1  0  1          5
#define  TONE_6    0x06  // 770   1477     6        0    1  1  0          6
#define  TONE_7    0x07  // 852   1209     7        0    1  1  1          7
#define  TONE_8    0x08  // 852   1336     8        1    0  0  0          8
#define  TONE_9    0x09  // 852   1477     9        1    0  0  1          9
#define  TONE_0    0x0A  // 941   1336     0        1    0  1  0          a
#define  TONE_mi   0x0B  // 941   1209     *        1    0  1  1          b
#define  TONE_pa   0x0C  // 941   1477     #        1    1  0  0          c
#define  TONE_A    0x0D  // 697   1633     A        1    1  0  1          d
#define  TONE_B    0x0E  // 770   1633     B        1    1  1  0          e
#define  TONE_C    0x0F  // 852   1633     C        1    1  1  1          f
#define  TONE_D    0x00  // 941   1633     D        0    0  0  0          0
const unsigned int SINE_WAVE_HIGH[256] = { // Sine wave amplitude range : 8 ~ 248
128,131,134,137,140,143,146,149,151,154,157,160,163,166,168,
171,174,177,179,182,185,187,190,192,195,197,199,202,204,206,
209,211,213,215,217,219,221,223,224,226,228,229,231,232,234,
235,236,238,239,240,241,242,243,244,244,245,246,246,247,247,
247,248,248,248,248,248,248,248,247,247,247,246,246,245,244,
244,243,242,241,240,239,238,236,235,234,232,231,229,228,226,
224,223,221,219,217,215,213,211,209,206,204,202,199,197,195,
192,190,187,185,182,179,177,174,171,168,166,163,160,157,154,
151,149,146,143,140,137,134,131,128,125,122,119,116,113,110,
107,105,102, 99, 96, 93, 90, 88, 85, 82, 79, 77, 74, 71, 69,
 66, 64, 61, 59, 57, 54, 52, 50, 47, 45, 43, 41, 39, 37, 35,
 33, 32, 30, 28, 27, 25, 24, 22, 21, 20, 18, 17, 16, 15, 14,
 13, 12, 12, 11, 10, 10,  9,  9,  9,  8,  8,  8,  8,  8,  8,
  8,  9,  9,  9, 10, 10, 11, 12, 12, 13, 14, 15, 16, 17, 18,
 20, 21, 22, 24, 25, 27, 28, 30, 32, 33, 35, 37, 39, 41, 43,
 45, 47, 50, 52, 54, 57, 59, 61, 64, 66, 69, 71, 74, 77, 79,
 82, 85, 88, 90, 93, 96, 99,102,105,107,110,113,116,119,122,
125};
CONST unsigned int SINE_WAVE_LOW[256] = { // Sine wave amplitude range : 43 ~ 213
128,130,132,134,136,138,140,143,145,147,149,151,153,155,157,
159,161,162,164,166,168,170,172,173,175,177,179,180,182,184,
185,187,188,190,191,192,194,195,196,197,199,200,201,202,203,
204,205,206,207,207,208,209,209,210,210,211,211,212,212,212,
213,213,213,213,213,213,213,213,213,212,212,212,211,211,210,
210,209,209,208,207,207,206,205,204,203,202,201,200,199,197,
196,195,194,192,191,190,188,187,185,184,182,180,179,177,175,
173,172,170,168,166,164,162,161,159,157,155,153,151,149,147,
145,143,140,138,136,134,132,130,128,126,124,122,120,118,116,
113,111,109,107,105,103,101, 99, 97, 95, 94, 92, 90, 88, 86,
 84, 83, 81, 79, 77, 76, 74, 72, 71, 69, 68, 66, 65, 64, 62,
 61, 60, 59, 57, 56, 55, 54, 53, 52, 51, 50, 49, 49, 48, 47,
 47, 46, 46, 45, 45, 44, 44, 44, 43, 43, 43, 43, 43, 43, 43,
 43, 43, 44, 44, 44, 45, 45, 46, 46, 47, 47, 48, 49, 49, 50,
 51, 52, 53, 54, 55, 56, 57, 59, 60, 61, 62, 64, 65, 66, 68,
 69, 71, 72, 74, 76, 77, 79, 81, 83, 84, 86, 88, 90, 92, 94,
 95, 97, 99,101,103,105,107,109,111,113,116,118,120,122,124,
126};
int8 index1,index2,inc1,inc2;
#INT_RTCC
void wave_generator()
   int16 wave;
   set_rtcc(25);           // when clock is 20MHz, interrupts every 100us
   wave   = SINE_WAVE_LOW[index1] ;
   wave  += SINE_WAVE_HIGH[index2];
   wave >>= 1;
   PORTD  = wave ;
   index1 += inc1;   //if(index1 >= 256)  index1 -= 256;  // Wu, 2003/02/26
   index2 += inc2;   //if(index2 >= 256)  index2 -= 256;
#define DTMF_ROW1   18  //18 for  697 Hz, increment this many times every 100us
#define DTMF_ROW2   20  //20 for  770 Hz,                     for SIN_WAVE[256]
#define DTMF_ROW3   22  //22 for  852 Hz,
#define DTMF_ROW4   24  //24 for  941 Hz,
#define DTMF_COLA   32  //32 for 1209 Hz,
#define DTMF_COLB   35  //34 for 1336 Hz, changed to 35, 2003/03/04
#define DTMF_COLC   38  //38 for 1477 Hz,
#define DTMF_COLD   43  //42 for 1633 Hz,
void generate_dtmf_tone(int8 keypad, long duration)  {
   index1=0;   index2=0;  inc1=0;   inc2=0;
   if     ((keypad== 1)||(keypad== 2)||(keypad== 3)||(keypad==13)) inc1=DTMF_ROW1;
   else if((keypad== 4)||(keypad== 5)||(keypad== 6)||(keypad==14)) inc1=DTMF_ROW2;
   else if((keypad== 7)||(keypad== 8)||(keypad== 9)||(keypad==15)) inc1=DTMF_ROW3;
   else if((keypad==11)||(keypad==10)||(keypad==12)||(keypad== 0)) inc1=DTMF_ROW4;
   if     ((keypad== 1)||(keypad== 4)||(keypad== 7)||(keypad==11)) inc2=DTMF_COLA;
   else if((keypad== 2)||(keypad== 5)||(keypad== 8)||(keypad==10)) inc2=DTMF_COLB;
   else if((keypad== 3)||(keypad== 6)||(keypad== 9)||(keypad==12)) inc2=DTMF_COLC;
   else if((keypad==13)||(keypad==14)||(keypad==15)||(keypad== 0)) inc2=DTMF_COLD;
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   enable_interrupts(INT_RTCC);
   while ( duration-- > 0 )  delay_us(1000);
   disable_interrupts(INT_RTCC);
   output_d(0);
Best wishes
rhuhong
EX_DTMF
PostPosted: Sat May 16, 2009 8:33 pm     Reply with quote
I tried to apply the EX_DTMF, but I am confused about the r-2r circuit. The circuits are connected to ports B or D because port 32-39 are from port B. Anyone can help? Wink
