Using the ICD to program without DEBUG enabled
splevy
PostPosted: Sun Oct 10, 2004 10:46 am     Reply with quote
The old Microchip ICD would allow you to turn off the debug function and program code for stand-alone operation. Is that also true for the ICD-S40?
My program is running fine with the ICD attached. Removing the DEBUG line and recompiling is successful, but when I try to enable the ICD to program the chip with what should be non-debug code, it offers to recompile with the debug option. If I decline, I can't use the ICD.
I must be missing something obvious, but any help would be appreciated.
Thanks.
Stan
Haplo
PostPosted: Sun Oct 10, 2004 4:56 pm     Reply with quote
It seems you are using the PCW debugger to program your chip. Use ICD.EXE instead, this should solve your problem.
splevy
PostPosted: Sun Oct 10, 2004 9:29 pm     Reply with quote
Thanks. That solved my problem.
I appreciate the help.
Stan
Smile
