i2c DS1621 stress !!!
coconico
PostPosted: Tue Aug 31, 2004 9:00 am     Reply with quote
I can send a good config to my DS1621 but the read function don't function good. It return a bad value and give no ack after the read blocks.
What can I do???
Pleas help me ...
jds-pic
Re: I2C DS1621 STRESS!!!
PostPosted: Tue Aug 31, 2004 1:32 pm     Reply with quote
What can I do???
Pleas help me ...
the DS1621 operates very much the same as the DS1624;
see my code for the latter here in the library section:
http://www.ccsinfo.com/forum/viewtopic.php?t=19526
jds-pic
Mark Weir
DS1621 Stress
PostPosted: Tue Aug 31, 2004 1:46 pm     Reply with quote
You may find that the problem comes back to the DS1621 device.
These have a tendency to lock up the I2C bus intermittently.
I have spent many hours chasing a similar problem recently using DS1621 and a 16F877A. The application would run perfectly for hours and then just lock up. I obtained some information from the Dallas Technical people stating known lock up issues with this device.
There are a number of other similar devices you could try, DS1631, DS1721, MAX7500. It depends on your requirements.
The only other thing is to check that nothing else is interfering with the bus traffic. Are there any AC devices in the area? it could be noise.
Cheers
Mark
HELL_FIRE_
PostPosted: Sun Dec 16, 2007 5:10 pm     Reply with quote
HI guys
With which one function I can replace BITEST function in CCS Compiler? I want to use compiler which did not support this function and to compile with him DS1624 driver code. Please help me Crying or Very sad
PostPosted: Sun Dec 16, 2007 5:40 pm     Reply with quote
Do you even have the CCS compiler ? CCS has had the bit_test()
function for years. But anyway, here is a bit_test() function:
Put these lines above the #include line for the ds1624 driver.
(Referring to the driver by jds-pic in the Code Library).
int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
#define bit_test(var, mybit) (!!(var & bitmask_table[mybit]))
CorosanD
PostPosted: Wed Jan 02, 2008 10:30 am     Reply with quote
Thank you very much Smile
aloisjidra
Re: DS1621 Stress
PostPosted: Wed Mar 18, 2009 4:54 pm     Reply with quote
Hi
I would like to ask you to help with max 7500 thermo i2c sensor.
I could not find command for this sensor. I mean for example start conversion, read data and so
Thank for your answer
Best regards
Alois
Cheers
Mark
