My LCD drives me mad!
deniska_gus
PostPosted: Thu Oct 05, 2006 2:57 am     Reply with quote
Hi, I'm using PIC16F877A and PCHW3.249
I have tested this small code
#include <16F877A.h>
#fuses XT,NOWDT,PUT, NOLVP
#include<lcd.c>
  lcd_putc("Hallo Welt!\n");
and it doesn't work. I'm using original lcd.c, Quarz 4Mhz. The pins are connected to Port D.
Please help!
PostPosted: Thu Oct 05, 2006 3:09 am     Reply with quote
A couple of thought/suggestions.
First add a delay. So:
  while(1)  {
You are continuously writing to the LCD, and some displays won't actually update if they are having to receive data 'flat out'.
Second, double check the connections. Make sure you have connected the 'high' four data pins, not the 'low' four.
deniska_gus
PostPosted: Thu Oct 05, 2006 3:36 am     Reply with quote
Thank you, Ttelmah, i have change it but it doesn't work. I have to say, i used the search function of this forum and i have added all i need to my plan( 10K trimpot etc.). I use 2X16 LCD Display with HD 44780 Controller. All i can see is just black line.
PostPosted: Thu Oct 05, 2006 5:23 am     Reply with quote
A single black line in the top half of the display, means it is not being initialised, which comes back to the connections. Triple check. The pinouts of displays differ, and even sometimes the pin names.
treitmey
PostPosted: Thu Oct 05, 2006 7:54 am     Reply with quote
And even sometimes the timming.
Someone else posted and little test. In the code, if there is a
delay set after reading/writeing pins, try doubling the time.
See if that helps.
deniska_gus
PostPosted: Thu Oct 05, 2006 8:08 am     Reply with quote
I'll try this. Thank you , guys.
Regards. Dennis.
P.S. If someone has any idea, so please write it. I have nobody else, who could help me.
PostPosted: Thu Oct 05, 2006 8:15 am     Reply with quote
Also, try inserting a delay _before_ starting lcd_init.
Many of the LCD's, require several mSec after 'power on', before they are ready to accept commands. For example, for Hitach chips, they say 'wait for at least 15mSec after power rises above 4.5v'.
Markdem
PostPosted: Thu Oct 05, 2006 4:56 pm     Reply with quote
One more thing you can try is putting a delay_ms(250); after the lcd_init() line. I have seen LCD that need a bit of time to get up and running.
Also, when you say all you can see is black line, is it only the top line, or is it the full screen?? If it is the full screen, just try to adjust the trim pot.
Have fun
Mark
asmallri
PostPosted: Thu Oct 05, 2006 6:29 pm     Reply with quote
Where are the pinouts to the LCD interface defined? Such as enable, write..
Regards, Andrew
deniska_gus
PostPosted: Thu Oct 05, 2006 11:06 pm     Reply with quote
to Markdem:
It is just the top line. I'll try delay_ms(250). Thank you.
to Asmallri
The Pinouts to the LCD interface are defined:
D0 -> enable (pin 6 LCD)
D1 ->RS (pin 4 LCD)
D2 ->RW (pin 5 LCD)
D4 -> D4 (pin 11 LCD)
D5 -> D5 (pin 12)
D6 -> D6 (pin 13)
D7 -> D7( pin 14)
Thank you
