elcrcp
Joined: 11 Mar 2016 Posts: 62 Location: izmir / Turkey
| couldn't use "getenv" |
Posted: Mon Jun 24, 2019 10:38 am |
18F25K40, v5.081
Hi guys, starting to write a new code, nothing to work yet, blank main function, only fuses and definitions. Problem is when I use "getenv" to define a register I get following error
| Code: | *** Error 103 "TEST_APP_v0.1.c" Line 20(5,8): Constant out of the valid range 000 is reserved by the compiler
but if I use it compiles. Ok register names are already predefined I know but also I know it normally works fine, I used it before but I can't understand why I cant use it this time.
c file | Code: |
#include <Test_inc.h>
delay_ms(1);
h file
#include <18F25K40.h>
#device ADC=10
#fuses NOEXTOSC //External Oscillator not enabled
#fuses RSTOSC_HFINTRC_64MHZ //Internal Osc 64MHz
#fuses NOCLKOUT //I/O function on OSC2
#fuses NOCKS //Clock Switching Disabled
#fuses MCLR //Master Clear pin enabled
#fuses PUT //Power Up Timer
#fuses NOFCMEN //Fail-safe clock monitor disabled
#fuses NOBROWNOUT //No brownout reset
#fuses ZCDDIS //Zero-cross detect circuit is disabled at POR
#fuses NOPPS1WAY //Allows multiple reconfigurations of peripheral pins
#fuses NOSTVREN //Stack full/underflow will not cause reset
#BYTE TRISA=GETENV("BYTE:TRISA")
#use delay(internal=64MHz)
_________________ There is nothing you can't do if you try |
elcrcp
Posted: Mon Jun 24, 2019 10:50 am |
Quick update, | Code: | | #BYTE TRISA=GETENV("SFR:TRISA") | works, but again, i was able to use "BYTE:TRISA" with a 16F1933 before. What is the difference?
Oookey, another quick update. Looks like 16 and 18 series differs on this point. You need to use SFR on 18 series it seems. _________________ There is nothing you can't do if you try |
Posted: Mon Jun 24, 2019 12:58 pm |
You claim that using "BYTE:TRISA" works with the 16F1933.
| Code: | #include <16F1933.h>
#use delay(internal=4M)
TRISA = 0x55;
while(TRUE);
When I compile the above test program with CCS vs. 5.085, I get
the following .LST file:
| Quote: | ...... TRISA = 0x55;
0014: MOVLW 55
0015: MOVWF 00 // This is the INDF register, not the TRISA reg
It fails. It "compiles", but it does not produce the correct code.
But if we change the getenv() statement to use "SFR", which is the
correct method for all PICs, then we get the correct result for the
16F1933:
0014: MOVLW 55
0015: MOVLB 01 // Bank 1
0016: MOVWF 0C // Register address 0x8C
Posted: Mon Jun 24, 2019 1:01 pm |
BYTE: is not a standard getenv construct.
The standard forms are BIT: and SFR:
Sounds as if BYTE: may have existed for some specific register names
on some chips in the past.
SFR: is the normal construct, and is what should be used.
I see PCM posted while I was typing.  |
elcrcp
Posted: Mon Jun 24, 2019 4:21 pm |
| PCM programmer wrote: | You claim that using "BYTE:TRISA" works with the 16F1933.
TRISA = 0x55;
while(TRUE);
0014: MOVLW 55
16F1933:
0014: MOVLW 55
That is interesting, I never had any problems with 1933 code I mentioned but I'll check my old compiled code tomorrow.
And I really don't remember why did I used BYTE in that code, probably I did a mistake while ctrl+c ctrl+v XD but again, I swear it was working just fine! _________________ There is nothing you can't do if you try |
elcrcp
Posted: Tue Jun 25, 2019 2:25 am |
Hi, I checked my old lst file, I dont know what is the difference but looks like it compiles right. I think I was lucky with that project XD
| Code: | .................... PIE1=0;
0050: MOVLB 01
0051: CLRF 11
.................... PIE2=0;
0052: CLRF 12
.................... PIE3=0;
0053: CLRF 13
.................... INTEDG=0;
0054: BCF 15.6
.................... TRISA=0b10111111;
0055: MOVLW BF
0056: MOVWF 0C |
