Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Library for using nokia 5110 lcd ?
Goto page Previous  1, 2
qwwe
PostPosted: Mon Dec 25, 2017 2:19 pm     Reply with quote
I wrote two different programs for each one:
This app is for testing the following function
nokia_bitmap(rom *bitmap,bx,by,xdim,ydim,color,align)
#include <16f1829.h>
#device *=16
#fuses HS             //High speed Osc (> 4mhz for PCM/PCH)
#fuses NOWDT            //NO Watch Dog Timer
#fuses PUT            //Power Up Timer
#fuses NOLVP          //No low voltage programing
#fuses NOCPD          //No EE protection
#fuses NOPROTECT      //Code not protected from reading
#fuses NOWRT          //Program memory not write protected
#fuses NODEBUG        //No Debug mode for ICD
#fuses NOBROWNOUT     //No brownout reset
#USE DELAY (crystal=11059200)
//#USE RS232(ENABLE=PIN_A2,BAUD=9600,XMIT=PIN_C4,RCV=PIN_C5,PARITY=N,BITS=8,STOP=1,ERRORS)
#include <stdio.h>
#include <string.h>
#include <Nokia_5110.c>
const char c[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
nokia_init();
nokia_bitmap(c,1,1,48,50,1,0);
nokia_refresh();
and
nokia_bigc(c)
#device *=16
#include <stdio.h>
#include <string.h>
int c=10;
nokia_init();
nokia_gotoxy(1,1);
nokia_bigc(c);
nokia_refresh();
PostPosted: Mon Dec 25, 2017 3:02 pm     Reply with quote
You are giving nokia_bigc() an input value that is not in the expected range.
int c=10;
nokia_init();
nokia_gotoxy(1,1);
nokia_bigc(c);
nokia_refresh();
The nokia_bigc() function has this note:
// Displays 10x12 pixels numerical characters (-. 0123456789)
So try this instead:
int c = '9';
Then you should see something. Note that nokia_bigc() expects ASCII
numbers, or the ASCII minus sign and period.
Re: nokia_bitmap() function:
The resolution of the Nokia display is only 84 x 48 (x, y).
But in the code below, you have 50 for the Y dimension. This is too large.
nokia_init();
nokia_refresh();
Try it with smaller numbers than 48, 50. Try it with 10, 10.
qwwe
PostPosted: Tue Dec 26, 2017 12:12 am     Reply with quote
Thanks to the problem solved with the following function.
nokia_bigc();
But the problem with the following function is still ongoing:
nokia_bitmap(rom *bitmap,bx,by,xdim,ydim,color,align);
Of course, when I determined the number of members of the array I defined, the image on the page was determined, along with the many errors that Proteus provided, all of which were as follows. And I did not get picture what I wanted:
[PIC16 EEPROM] PC=0x025B. Address for read/write of program memory (0x202B) is outside of the memory (8192 words) - address has been wrapped. [U1]
PostPosted: Tue Dec 26, 2017 6:17 am     Reply with quote
I had a look at the driver, again, and it only does very basic testing for valid x,y numbers. As the programmer, it is your job to ensure values for x,y, etc. are valid and within the range of the device. The same holds true for storing of images or other data into the PIC memory.
While there are 'tricks' to storing lots of data into small memory, these days you just buy a 'bigger' PIC.
PostPosted: Tue Dec 26, 2017 6:53 am     Reply with quote
Also (sneaking suspicion), he may be trying to store an image that is too large for the ROM on this PIC.
PostPosted: Tue Dec 26, 2017 7:34 am     Reply with quote
but.. I've seen 20 clowns come out of a small car at the circus !
You're probably right though; BIG image, small EEPROM.
When you have limited 'resources' you need to think 'outside the box' and design code accordingly. These days it typically takes 6 bytes to store a time variable, when 30 years ago I did it in 1 byte and had a bit leftover. For my application, remote energy control [setback on/off times], it's worked exceedingly well, still does today.
qwwe
PostPosted: Tue Dec 26, 2017 11:32 pm     Reply with quote
Mr. PCM programmer Do not you know what the problem is?
Thanks for help.
PostPosted: Wed Dec 27, 2017 1:08 am     Reply with quote
Post a new test program that has a much smaller bitmap. Post the
complete const array data. Don't use "...". Also, don't use data that
is all 0x00, 0x00, 0x00, etc.
Post what you expect to see on the Nokia LCD, and also post what you
actually see. For example:
"I expect to see a solid square that is 5 x 5 pixels in the upper left corner
of the screen". "But I actually see nothing. The screen is blank".
Page 2 of 2
