Timer0 nor timer1 does not burst.
Goto page Previous  1, 2
PostPosted: Thu Nov 09, 2017 11:05 am     Reply with quote
The command to read a pin without changing it is 'output_state'.
if (output_state(PIN_B1)==0)
tests that pin B1 is low, without changing it to be an input.
jacktaylor
Thank you Ttelmah
PostPosted: Fri Nov 10, 2017 9:42 am     Reply with quote
This if (output_state (PIN_B1) == 0) command does not appear in the ccs manual.
And when I enter it in my code, it presents error in the complication:
*** Error 12 "RelogDispl7Seg.c" Line 42 (22,23): Undefined identifier - output_state
PostPosted: Fri Nov 10, 2017 9:45 am     Reply with quote
It actually should be input_state(). Try that. That's in the manual.
PostPosted: Fri Nov 10, 2017 9:49 am     Reply with quote
Embarassed
jacktaylor
Thank you friend PCM programmer
PostPosted: Sun Nov 12, 2017 3:31 pm     Reply with quote
jacktaylor
Thank you Ttelmah
PostPosted: Sun Nov 12, 2017 3:32 pm     Reply with quote
Thank you friend Ttelmah
Wink Wink
Page 2 of 2
