artohautala
Posted: Sun Nov 12, 2017 11:55 am |
temtronic wrote: | Here's a link to what I've been using, connects to PIC via I2C:
https://www.banggood.com/DS3231-AT24C32-IIC-High-Precision-Real-Time-Clock-Module-For-Arduino-p-81066.html
Only $3 CDN and comes WITH battery ! One actually had a rechargeable battery in it !! I bought 5 pcs.
I haven't done any long term testing, though the 'specs' says it's a lot better than the DS1307
GPS NEEDS a clear 'line of sight', so a metal roof kills the signals. The only way around that is to put GPS + HC-12 outside and transmit to the PIC time project.
HI temtronic,
I tested many days that RF link easy to use module :
robokits RKI-1197 ... it worked about 2 or 4 hours now and then ... but then it tried to RX and TX same time ...
and sure there was any communication anymore between RX and TX.... !
... maybe some error checking because there's lot of signals in the air all the time ... but I don't know how ...
... I think RF communication is very complicated if we try to avoid data errors ?
I wonder if HC-12 works better ?
any idea ?
brdgs
-arto- |
artohautala
Posted: Sun Nov 12, 2017 12:16 pm |
Hi temtronic,
I tested many days that RF link easy to use module: Robokits RKI-1197.
It worked about 2 or 4 hours now and then, but then it tried to RX and TX same time, and sure there was any communication anymore between RX and TX!
Maybe some error checking because there's lot of signals in the air all the time, but I don't know how.
Any idea ?
brdgs
-arto- |
Posted: Sun Nov 12, 2017 2:28 pm |
The basic simple way is just to add a checksum.
Transmit more frequently than you need.
Simply test the checksum, and reject the packet if it isn't right. |
