srikrishna
Posted: Fri Nov 03, 2017 4:44 pm |
Yes |
Posted: Sat Nov 04, 2017 12:30 am |
So, change the thread title to include [solved].... |
srikrishna
Posted: Wed Nov 08, 2017 1:01 am |
But it is for one sensor. I am not very good in programming but tried to convert it for 5 sensor using array. If anything is wrong in this program please help me.
Code: | #include <18f2550.h>
#device adc=10
#include <math.h>
#include <stdlib.h>
#include <stdio.h>
#FUSES HS,NOWDT
#USE delay(clock=20M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,PARITY=N,BITS=8)
#USE TIMER(TIMER=1,TICK=1s,BITS=16,NOISR)
unsigned int16 tick_difference(unsigned int16 current,unsigned int16 previous)
return (current - previous);
double map(double value, float min, float max, float y_min, float y_max)//function definition
return (y_min + (((y_max - y_min)/(max - min)) * (value - min)));
typedef struct
unsigned int16 min[5];
unsigned int16 max[5];
} calibration_t; //calibration_t is the new name of our structure definition
void calibrate_adc(calibration_t *calibration_data)//calibration_t is structure variable
unsigned int16 current_tick;
unsigned int16 starting_tick;
unsigned int16 sensor_value[]={0,0,0,0,0};
unsigned int16 max[] = {0,0,0,0,0};
unsigned int16 min[] = {1023,1023,1023,1023,1023};
unsigned int8 i;
delay_us(15);
starting_tick = current_tick = get_ticks();
//get as many readings as you can. the more the
//merrier
while(tick_difference(current_tick,starting_tick) < 5)
for (i=0;i<5;i++)
set_adc_channel(i);
delay_us(15);
sensor_value[i] = read_adc();
delay_us(15);
if(sensor_value[i] > max[i])
max[i] = sensor_value[i];
if(sensor_value[i] < min[i])
min[i] = sensor_value[i];
output_toggle(PIN_B0);
calibration_data->min[i] = min[i]; //a->b is just short for (*a).b in every way (same for functions: a->b() is short for (*a).b()).
calibration_data->max[i] = max[i]; //(*calibration_data).max,
//(*calibration_data).min = min[i];//a->b is equivalent to (*a).b, i.e. it gets the member called b from the struct that a points to.
//(*calibration_data).max = max[i];
calibration_t cal;// structure varible
double map_result[]={0,0,0,0,0};
unsigned int8 i;
SETUP_ADC_PORTS( AN0_TO_AN4_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
delay_ms(1000); //some delay to stabilize sensor
calibrate_adc(&cal); //takes about 5 secs
//next two lines not technically needed
//since you only have one ADC and it
//was set in calibrate_adc(), but here
//for later expansion
delay_us(15);
for (i=0;i<5;i++)
set_adc_channel(i);
delay_us(15);
map_result[i] = map(sensor_value[i],cal.min[i],cal.max[i],0,1023);
printf("%f \r\n",map_result[i]);
Posted: Wed Nov 08, 2017 1:50 am |
One thing doesn't matter but worth changing. Use 'float' not 'double'. Your PIC does not have a 'double' type. The compiler will automatically be changing all references to double into standard floats, so you might as well do this yourself...
However the area that will cause problems is this:
set_adc_channel(i);
delay_us(15);
map_result = map(sensor_value[i],cal.min,cal.max,0,1023);
printf("%f \r\n",map_result);
delay_ms(1000)
Change to:
set_adc_channel(i);
delay_us(15);
map_result = map(sensor_value[i],cal.min[i],cal.max[i],0,1023);
delay_ms(1000)
There has to be a delay (depending on the chip), of between 2uSec and 10uSec (or slightly more), between selecting an ADC channel, and reading it.
Your calibration code has 15uSec here, but the main code does not. It instead has a pointless 15uSec delay between the reading and doing the maths....
The other problem is you need to be reading the cal for the channel in the map function. You are using cal.min, not cal.min[i] (and the same for max)..... |
srikrishna
Posted: Wed Nov 08, 2017 3:06 am |
ok I have corrected it . it is my request please check the code carefully.I am not a very good programmer and i have not worked previously with structure and pointer in embedded environment .
and is this part is ok ??
I have done it by guess.I am not sure |
Posted: Wed Nov 08, 2017 3:21 am |
Not quite....
What is 'i' at this point?. It is not 0 to 5...
The structure reference is OK, but you need to copy all five min's and max's to the external array. |
srikrishna
Posted: Wed Nov 08, 2017 5:26 am |
Ttelmah wrote: | Not quite....
I think now it is ok |
