ntrungtruc2003
The problem with read parameter dig_H4 |
Posted: Wed Aug 02, 2017 10:33 pm |
Dear Sir.
I have a problem when read dig_H4 in BME280 sensor
dig_4 return 29 = 11101
but the value true must be 285
0xE4 = 17 10001
0xE5= 13 1101
285 = 1001 1101 = 0XE4*16 + 0xE5
29 = 11101 = 0xE4 + 0xE5
BMEReadDig_H4 like this
unsigned int16 dig_H4;
unsigned int16 BME280ReadDig_H4()
unsigned int16 temp;
byte msb, lsb;
msb = BME280ReadByte(0xE4);
lsb = BME280ReadByte(0xE5);
temp = msb*16 + lsb;
return temp;
ccs compiler v5.015 |
Posted: Thu Aug 03, 2017 1:43 am |
As a comment, it is pointless doing repeated byte reads of these registers. The whole point is that if you read one register, the internal counter increments and a second read without re-addressing will then read the next register. Far better to read the whole block of calibration registers in one operation.
Then you are misunderstanding how the registers have to combined.
The value needs to be put into a signed int16, with the top register rotated left by 4, and only the four bottom bits of the second register used.
So:
byte msb, lsb;
temp = ((int16)msb<<4) + (lsb & 0xF);
return temp;
The resulting calibration can be -ve, which is why it is meant to be read as a signed value. However I've never actually seen a -ve value. However Bosch do specify this to be returned as a signed int16.
The register value needs to be moved into a 16bit memory 'space' before you rotate it, and the high bits of the second register should also be removed before combining.. |
ntrungtruc2003
Problem with read pressure BME280 |
Posted: Fri Aug 04, 2017 3:48 am |
Dear Sir
The sensor works well with temperature and humidity, but with pressure's value i have a problem.
The pressure's value return is about 1646, it is greater than 1002 (1002 hpa is the true value).
All of dig_P is correct.
Quote: |
dig_P1 37621
dig_P2 -10728
dig_P3 3024
dig_P4 8061
dig_P5 -139
dig_P6 -7
dig_P7 9900
dig_P8 -10230
dig_P9 4285
adc_P is about 5164160
I have also tested "step by step" in the function ME280_compensate_P_int32().
unsigned int32 BME280_compensate_P_int32()
unsigned int32 adc_P = BME280Read24(0xF7); //FA THE TEMPERATURE REGISTER
if (adc_P == 0x800000) // value in case temp measurement was disabled
return 0;
adc_T >>= 4;
signed int32 var1, var2;
unsigned int32 p;
//BME280ReadTemperature(); //must be done to get t_fine
var1 = ((t_fine)>>1) - (unsigned int32)64000;
delay_us(100);
var1_p = var1; //test
var11_p = (int32)(168278)>>1; //test
var2 = (((var1>>2) * (var1>>2)) >> 11 ) * ((signed int32)dig_P6); // dig_p6 is negative
var2_p = var2; //test
var2 = var2 + ((var1*((signed int32)dig_P5))<<1); // dig_p5 is negative therefore left shift is OK ? shift left is ok
var3_p = var2; //test
var33_p = ((signed int32)dig_P5)<<1;
var2 = (var2>>2)+(((signed int32)dig_P4)<<16);
var4_p = var2; //test
var44_p = (signed int32)dig_P4<<16; //test
var444_p = var2>>2; //test
var4444_p = ((signed int32)-87129)>>2; //only for test this function
var1 = (((dig_P3 * (((var1>>2) * (var1>>2)) >> 13 )) >> 3) + ((((signed int32)dig_P2) * var1)>>1))>>18;
var5_p = var1; //test
var1 =((((32768+var1))*((signed int32)dig_P1))>>15);
var6_p = var1; //test
if (var1 == 0)
return 0; // avoid exception caused by division by zero
p = (((unsigned int32)(((signed int32)1048576)-adc_P)-(var2>>12)))*3125;
var7_p = p; //test
if (p < 0x80000000)
p = (p << 1) / ((unsigned int32)var1);
p = (p / (unsigned int32)var1) * 2;
var1 = (((signed int32)dig_P9) * ((signed int32)(((p>>3) * (p>>3))>>13)))>>12;
var8_p = var1; //test
var2 = (((signed int32)(p>>2)) * ((signed int32)dig_P8))>>13;
var9_p = var2; // the test value
p = (unsigned int32)((signed int32)p + ((signed int32)(var1 + var2 + dig_P7) >> 4));
return p/100;
After that i have a table to compare, the left column is not true, the right column is true value that i want to achieve.
var1_p(32 bit) 20197------------------------------ 21514
var2_p(32 bit) -87129-----------------------------( -98854)
var3_p(32 bit) -5701895-------------------------- (-6079476)
var4_p(32 bit) 1600602046----------------------- 526765759
var5_p(32 bit) 8879--------------------------------( -436)
var6_p(32 bit) 478814----------------------------- 37120
I have also checked with shift signed int32, it's ok.
Could you please give me some advice.
Thanks you so much. |
Gabriel
Posted: Fri Aug 04, 2017 6:27 am |
I'm having problems with the Humidity value (i don't trust it at least)..... but i got the pressure spot on....
I'll load up my driver later today and we can possibly make a viable driver merging code.
G. _________________ CCS PCM 4.135 - PIC: 16F886, 88', 876' 877A
CCS PCH 5.012 - PIC: 18F97j60 |
Posted: Fri Aug 04, 2017 7:14 am |
The most likely problem is the one I already pointed out about sign extending on the shifts.
Don't use the default shifts on the signed values.
K&R is quite specific that a shift on a signed number is 'implementation specific'. It is _not_ something that can be moved between processors reliably....
This is also stated in the ANSI C specifications as well.
It just happens that on the most common processors today, when dealing with signed numbers, most perform arithmetic shifts.
Replace the shifts yourself. Safest is to generate a macro to do the shifts:
#define A_SHRT(x,y) (x>0)?(x>>y):(-((-x)>>y))
#DEFINE A_SHLT(x,y) (x>0)?(x<<y):(-((-x)<<y))
Then where you have (for instance) x>>4 you would use A_SHRT(x,4).
This guarantees an 'arithmetic shift', rather than the PIC standard logical shift. |
Gabriel
Posted: Fri Aug 04, 2017 8:19 am |
Code: | #define BME280 0x77 //The I2C Address of the Device
void Write_BME_Register(int,int,int);
int Read_BME_Register(int,int);
void Get_BME_Data(int, int);
void Setup_BME();
void Calculate_Temp();
void Calculate_Hum();
void Calculate_Pess();
float Temperature;
signed int32 t_fine;
int32 Pressure;
int32 rawpres;
int32 rawtemp;
int32 rawhum;
int16 Dig_T1;
signed int16 Dig_T2;
signed int16 Dig_T3;
int16 Dig_H1;
signed int16 Dig_H2;
int16 Dig_H3;
signed int16 Dig_H4;
signed int16 Dig_H5;
signed int16 Dig_H6;
int16 Dig_P1;
signed int16 Dig_P2;
signed int16 Dig_P3;
signed int16 Dig_P4;
signed int16 Dig_P5;
signed int16 Dig_P6;
signed int16 Dig_P7;
signed int16 Dig_P8;
signed int16 Dig_P9;
void Setup_BME()
Write_BME_Register(BME280,0xF4,0x00); //Put it in sleep mode
delay_ms(2000);
Write_BME_Register(BME280,0xF5,0x84); //Set Config Word
Write_BME_Register(BME280,0xF2,0x04); //Set Huidity Control
Write_BME_Register(BME280,0xF4,0x93); //Set Temp & Press Control + Mode
Dig_T1 = make16 (Read_BME_Register(BME280,0x89),Read_BME_Register(BME280,0x88));
Dig_T2 = make16 (Read_BME_Register(BME280,0x8B),Read_BME_Register(BME280,0x8A));
Dig_T3 = make16 (Read_BME_Register(BME280,0x8D),Read_BME_Register(BME280,0x8C));
Dig_H1 = Read_BME_Register(BME280,0xA1);
Dig_H2 = make16 (Read_BME_Register(BME280,0xE2),Read_BME_Register(BME280,0xE1));
Dig_H3 = Read_BME_Register(BME280,0xE3);
Dig_H4=(((int16)Read_BME_Register(BME280,0xE4)<<4)|(Read_BME_Register(BME280,0xE5)& 0x0F));
// Dig_H5 = make16((Read_BME_Register(BME280,0xE5)>>4), Read_BME_Register(BME280,0xE6));
// Dig_H4 = make16((Read_BME_Register(BME280,0xE4)<<4),(Read_BME_Register(BME280,0xE5)& 0x0F));
// Dig_H5 = make16((Read_BME_Register(BME280,0xE6)<<4), ((Read_BME_Register(BME280,0xE5)>>4)&0x0F));
// Dig_H4 = (Read_BME_Register(BME280,0xE4)<<4|(Read_BME_Register(BME280,0xE5) & 0x0F));
// Dig_H5 = (Read_BME_Register(BME280,0xE6)<<4|(Read_BME_Register(BME280,0xE5) >>4));
Dig_H5 = make16((Read_BME_Register(BME280,0xE6)<<4),(Read_BME_Register(BME280,0xE5) >>4));
Dig_H6 = Read_BME_Register(BME280,0xE7);
Dig_P1 = make16 (Read_BME_Register(BME280,0x8F),Read_BME_Register(BME280,0x8E));
Dig_P2 = make16 (Read_BME_Register(BME280,0x91),Read_BME_Register(BME280,0x90));
Dig_P3 = make16 (Read_BME_Register(BME280,0x93),Read_BME_Register(BME280,0x92));
Dig_P4 = make16 (Read_BME_Register(BME280,0x95),Read_BME_Register(BME280,0x94));
Dig_P5 = make16 (Read_BME_Register(BME280,0x97),Read_BME_Register(BME280,0x96));
Dig_P6 = make16 (Read_BME_Register(BME280,0x99),Read_BME_Register(BME280,0x98));
Dig_P7 = make16 (Read_BME_Register(BME280,0x9B),Read_BME_Register(BME280,0x9A));
Dig_P8 = make16 (Read_BME_Register(BME280,0x9D),Read_BME_Register(BME280,0x9C));
Dig_P9 = make16 (Read_BME_Register(BME280,0x9F),Read_BME_Register(BME280,0x9E));
void Write_BME_Register(int Dev_Read_Add, int Register_add, int Data)
//int readbit =1;
//int writebit =0;
int tempaddress = 0;
tempaddress = Dev_Read_Add <<1; //Left Shift 1 bit to allow space for R/W bit
//tempaddress |= writebit; //OR the shifted address with the WRITE Bit
i2c_start();
i2c_write(tempaddress); //Address the device with shifted address with WRITE bit set
i2c_write(Register_add); //Tell the Device Which Register you want to read
i2c_write(Data);
i2c_stop();
int Read_BME_Register(int Dev_Read_Add, int Register_add)
//int readbit=1;
//int writebit=0;
int tempaddress=0;
int Result_Byte=0;
// tempaddress |= 0x00; //OR the shifted address with the WRITE Bit
i2c_start(); //Start I2C sequence
// tempaddress = Dev_Read_Add <<1; //Left Shift 1 bit to allow space for R/W bit
tempaddress |= 0x01; //OR the shifted address with the READ Bit
i2c_write(tempaddress); //Address the device with shifted address with READ bit set
Result_Byte = i2c_read(0); //READ the data onto a Variable - Device ID in this case
i2c_stop(); //Stop The I2C transaction
//fprintf(lcd_putc,"Register:%X\n\r", Result_Byte); //Print your Data --- For the Win.
return(Result_Byte);
float var1, var2, p;
var1 = ((float)t_fine/2.0) - 64000.0;
var2 = var1 * var1 * ((float)Dig_P6) / 32768.0;
var2 = var2 + var1 * ((float)Dig_P5) * 2.0;
var2 = (var2/4.0)+(((float)Dig_P4) * 65536.0);
var1 = (((float)Dig_P3) * var1 * var1 / 524288.0 + ((float)Dig_P2) * var1) / 524288.0;
var1 = (1.0 + var1 / 32768.0)*((float)Dig_P1);
if (var1 == 0.0)
//return 0; // avoid exception caused by division by zero
p = 1048576.0 - (float)rawpres;
p = (p - (var2 / 4096.0)) * 6250.0 / var1;
var1 = ((float)Dig_P9) * p * p / 2147483648.0;
var2 = p * ((float)Dig_P8) / 32768.0;
p = p + (var1 + var2 + ((float)Dig_P7)) / 16.0;
fprintf(lcd_putc,"PRESSURE: %4.2f\n\r",(p/100.0)); //Print your Data --- For the Win.
int32 var1;
var1 = (t_fine - ((int32)76800));
var1 = (((((rawhum << 14) - (((int32)Dig_H4) << 20) - (((int32)Dig_H5) * var1)) + ((int32)16384)) >> 15) * (((((((var1 * ((int32)Dig_H6)) >> 10) * (((var1 * ((int32)Dig_H3)) >> 11) + ((int32)32768))) >> 10) + ((int32)2097152)) *((int32)Dig_H2) + 8192) >> 14));
var1 = (var1 - (((((var1 >> 15) * (var1 >> 15)) >> 7) * ((int32)Dig_H1)) >> 4));
var1 = (var1 < 0 ? 0 : var1);
var1 = (var1 > 419430400 ? 419430400 : var1);
var1= var1>>12;
fprintf(lcd_putc,"HUMIDITY: %3.2f \n\r",((float)var1/1024.0)); //Print your Data --- For the Win.
float var1, var2, T;
var1 = (((float)rawtemp)/16384.0 - ((float)Dig_T1)/1024.0) * ((float)Dig_T2);
var2 = ((((float)rawtemp)/131072.0 - ((float)Dig_T1)/8192.0) *
(((float)rawtemp)/131072.0 - ((float) Dig_T1)/8192.0)) * ((float)Dig_T3);
t_fine = (signed int32)(var1 + var2);
Temperature = (var1 + var2) / 5120.0;
fprintf(lcd_putc,"TEMPERATURE: %3.2f \n\r",Temperature); //Print your Data --- For the Win.
void Get_BME_Data(int Dev_Read_Add, int Register_add)
// int readbit =1;
// int writebit =0;
int Temp[8];
// tempaddress |= writebit; //OR the shifted address with the WRITE Bit
Temp[0]= i2c_read(1); //0xF7
Temp[1]= i2c_read(1); //0xF8
Temp[2]= i2c_read(1); //0xF9
Temp[3]= i2c_read(1); //0xFa
Temp[4]= i2c_read(1); //0xFb
Temp[5]= i2c_read(1); //0xFc
Temp[6]= i2c_read(1); //0xFd
Temp[7]= i2c_read(0); //0xFe
rawpres = make32(0x00, Temp[0], Temp[1],Temp[2]);
rawpres >>= 4;
rawtemp = make32(0x00, Temp[3], Temp[4],Temp[5]);
rawtemp >>= 4;
rawhum = make32(0x00,0x00,Temp[6],Temp[7]);
In Main:
Code: | Setup_BME();
fprintf(lcd_putc,"\fBME-------------------------------------------------------\n\r");
Get_BME_Data(BME280, 0xF7);
Calculate_Temp();
Calculate_Hum();
Calculate_Pess();
Gabriel
Posted: Fri Aug 04, 2017 8:21 am |
I am almost certain my problem is with DIG_H4 and DIG_H5.
I agree with Ttelmah that the shifts may be responsible for the errors.
Please note this is most definitely trial an error code with a lot of "ill fix that once i get it working" - like int functions that i have voided etc... none existant return paths... and the likes... _________________ CCS PCM 4.135 - PIC: 16F886, 88', 876' 877A
ntrungtruc2003
Posted: Fri Aug 04, 2017 11:23 am |
Thanks all of you so much
Thanks to Gabriel for your pressure calculating code.
BME280.c
All of sensors in BME280 work perfect for me.
PIC16F887
I2c software
D0------ SCL
D1------SDA
PIC16F
// BME280 Barometric Pressure Sensor
// - Datasheet: https://cdn-shop.adafruit.com/datasheets/BST-BME280_DS001-10.pdf
// - Written in CCS PCH C using floating point math
// - Several integer math versions of this driver exist but the speed improvement is
// not warranted in typical weather station type applications
// - Based on a paper posted to thebackshed.com by
// https://learn.adafruit.com/adafruit-bme280-humidity-barometric-pressure-temperature-sensor-breakout/wiring-and-test
// Revision - integer algotihm
// 07/24/2017
// Nguyen Trung Truc
// 08/17/12
// place a #use i2c statement in the main program and comment this out if not applicable
//#define BME280_SDA PIN_C4
//#define BME280_SCL PIN_C3
#use i2c(master, sda=PIN_D0, scl=PIN_D1, FORCE_SW)
#define BME280_ADDRESS 0xEE // I2C address of BME280 VDD
#define A_SHRT(var2,y) (var2>0)?(var2>>y):(-((-var2)>>y))
#define A_SHLT(x,y) (x>0)?(x<<y):(-((-x)<<y))
//#include <math.h>
//#include<stdint.h>
//calibration values of BME280
static unsigned int16 dig_T1;
static signed int16 dig_T2;
static signed int16 dig_T3;
static unsigned int16 dig_P1;// = 37621;
static signed int16 dig_P2;
static signed int16 dig_P3;
static signed int16 dig_P4;
static signed int16 dig_P5;
static signed int16 dig_P6;
static signed int16 dig_P7;
static signed int16 dig_P8;
static signed int16 dig_P9;
static unsigned int8 dig_H1;
static signed int16 dig_H2;
static unsigned int8 dig_H3;
static unsigned int16 dig_H4;
static signed int16 dig_H5;
static signed int8 dig_H6;
static signed int32 t_fine;//var1, var2;
static signed int32 var1_p, var2_p, var3_p, var4_p, var5_p, var6_p, var7_p, var8_p, var9_p, var11_p, var33_p, var44_p, var444_p, var4444_p;
static unsigned int32 adc_P, adc_T;
static unsigned int16 adc_H;
static int8 data[8];
int8 BME280ReadByte(int8 address);
int16 BME280ReadInt(int8 address) ;
int32 BME280Read24(int8 data);
void BME280WriteByte(int8 address, int8 data) ;
int1 BME280ReadingCalibration(void);
void BME280Calibration();
void BME280SetSampling();
void init_BME280()
output_float(PIN_D0);
output_float(PIN_D1);
int1 BME280Begin()
// check if sensor, i.e. the chip ID is correct
if(BME280ReadByte(0xD0) != 0x60)
return 0;
// reset the device using soft-reset
// this makes sure the IIR is off, etc.
BME280WriteByte(0xE0, 0xB6);
// wait for chip to wake up.
delay_ms(300);
// if chip is still reading calibration, delay
while ( BME280ReadingCalibration())
BME280Calibration(); // read trimming parameters, see DS 4.2.2
BME280SetSampling(); // use defaults
return 1;
BME280WriteByte(0xF2,0x03); // oversampling x 4, ctr_hum
BME280WriteByte(0xF5,0x68); //011 (250ms tstandby) 0100 (filter coefficient =4) 0 (i2c)
BME280WriteByte(0xF4,0x6E);// 011 011 10 temperature oversampling x 4, pressure oversampling x 4, force mode
// you must make sure to also set REGISTER_CONTROL after setting the
// CONTROLHUMID register, otherwise the values won't be applied (see DS 5.4.3)
// write8(BME280_REGISTER_CONTROLHUMID, _humReg.get());
// write8(BME280_REGISTER_CONFIG, _configReg.get());
// write8(BME280_REGISTER_CONTROL, _measReg.get());
int8 BME280ReadID()
int8 data;
i2c_start();
i2c_write(0xEE); // 0X77 11101110X IS IC ADDRESS, 0X76 IS 1110 110
i2c_write(0xD0);
i2c_start();
i2c_write(0xEF );
data=i2c_read(0);
i2c_stop();
delay_us(20);
return(data);
byte BME280ReadByte(int8 address)
byte data;
i2c_start();
i2c_write(BME280_ADDRESS);
i2c_write(address);
i2c_start();
i2c_write(BME280_ADDRESS | 0x01 );
data=i2c_read(0);
i2c_stop();
return(data);
int16 BME280Read16(int8 address)
byte msb, lsb;
i2c_start();
i2c_write(address);
i2c_start();
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
temp = msb*256 + lsb; //(msb<<8)|lsb;
return ( temp );
@brief Reads a signed 16 bit value over I2C or SPI
int16 BME280ReadS16(int8 address)
return ((signed int16)BME280Read16(address));
unsigned int16 BME280Read16_LE(int8 address)
temp = BME280Read16(address);
temp = (temp >> 8) | (temp << 8);
return (unsigned int16)temp;
signed int16 BME280ReadS16_LE(int8 address)
return (signed int16)BME280Read16_LE(address);
i2c_start();
i2c_write(address);
i2c_write(data);
i2c_stop();
byte msb, lsb;
return temp;
dig_T1 = BME280Read16_LE(0x88);
dig_T2 = BME280ReadS16_LE(0x8A);
dig_T3 = BME280ReadS16_LE(0x8C);
dig_P1 = BME280Read16_LE(0x8E);
dig_P2 = BME280ReadS16_LE(0x90);
dig_P3 = BME280ReadS16_LE(0x92);
dig_P4 = BME280ReadS16_LE(0x94);
dig_P5 = BME280ReadS16_LE(0x96);
dig_P6 = BME280ReadS16_LE(0x98);
dig_P7 = BME280ReadS16_LE(0x9A);
dig_P8 = BME280ReadS16_LE(0x9C);
dig_P9 = BME280ReadS16_LE(0x9E);
dig_H1 = BME280ReadByte(0xA1);
dig_H2 = BME280ReadS16_LE(0xE1);
dig_H3 = BME280ReadByte(0xE3);
dig_H4 = BME280ReadDig_H4(); //285
dig_H5 = (BME280ReadByte(0xE6)<<4)|(BME280ReadByte(0xE5) >>4) ;
dig_H6 = (signed int8)BME280ReadByte(0xE7);
// Read the uncompensated temperature value
void BurstRead()
// int8 data[8];
i2c_start();
i2c_write(0xF7);
i2c_start();
i2c_write(BME280_ADDRESS | 0x01);
data[0] = i2c_read();
data[1] = i2c_read();
data[2] = i2c_read();
data[3] = i2c_read();
data[4] = i2c_read();
data[5] = i2c_read();
data[6] = i2c_read();
data[7] = i2c_read();
i2c_stop();
//ata[5]=data[5]&0xF0;
adc_P = make32(0,data[0],data[1],data[2]);
// adc_T = make32(0,data[3],data[4]);
adc_T = make32(0,data[3],data[4],data[5]);
adc_H = make16(data[6],data[7]);
// Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
unsigned int32 BME280Read24(int8 data)
unsigned int32 value;
int8 msb, lsb, xlsb;
i2c_start();
i2c_write(data);
i2c_start();
msb = i2c_read();
lsb = i2c_read();
xlsb = i2c_read(0); // NACK on last read
i2c_stop(); //*/
value = make32(0,msb,lsb,xlsb); // (msb<<16)|(lsb<<8)|xlsb ;
return value;
// unsigned int8 const rStatus = BME280ReadByte(0xF3);
int8 rStatus = BME280ReadByte(0xF3);
return (rStatus & (1 << 0)) != 0; // return 1 if bus is busy reading 1<<0 is 1 shifted left 0 times
void BME280TakeForcedMeasurement()
BME280WriteByte(0xF4,0x6E); //011 011 01 pressure oversampling x 4, temperature oversampling x 4, forced mode
while (BME280ReadByte(0xF4) & 0x08) // wait until measurement has been completed, otherwise we would read the values from the last measurement
delay_us(10);
float BME280ReadTemperature(void)
//signed int32 adc_T = BME280Read24(0xFA); //FA THE TEMPERATURE REGISTER
if (adc_T == 0x800000) // value in case temp measurement was disabled
return 0;
adc_T >>= 4;
var1 = ((((adc_T>>3) - ((signed int32)dig_T1 <<1)))*((signed int32)dig_T2)) >> 11;
var2 = (((((adc_T>>4) - ((signed int32)dig_T1)) * ((adc_T>>4) - ((signed int32)dig_T1))) >> 12) *((signed int32)dig_T3)) >> 14;
t_fine = var1 + var2;
float T= (t_fine * 5 + 128) >> 8;
return T/100;
//signed int32 adc_P = BME280Read24(0xF7); //FA THE TEMPERATURE REGISTER
return 0;
adc_P >>= 4;
signed int32 var1, var2, var3;
unsigned int32 p;
t_fine = t_fine +2000;
var1 = (((signed int32)t_fine)>>1) - (unsigned int32)64000;
//delay_us(100);
var2 = var2 + ((var1*((signed int32)dig_P5))<<1); // dig_p5 is negative therefore left shift is OK ? sfhit left is ok
var2 = A_SHRT(var2,2)+(((signed int32)dig_P4)<<16);
var3=(signed int32)dig_P2 * var1;
var3 = A_SHRT(var3,1);
var3 = ((dig_P3 * ((A_SHRT(var1,2) *A_SHRT(var1,2)) >> 13 )) >> 3)+ var3;
var1= A_SHRT(var3,18);
var5_p = var1;
var1 = (32768+var1)*(signed int32)dig_P1;
var1 = A_SHRT(var1,15);
if (var1 == 0)
p = (((unsigned int32)(((signed int32)1048576) - adc_P)- A_SHRT(var2,12)))*3125;
//p = (((unsigned int32)(((signed int32)1048576) - adc_P)-(var2>>12)))*3125;
if (p < 0x80000000)
//var2 = (((signed int32)(p>>2)) * ((signed int32)dig_P8))>>13;
var2 = (((signed int32)(p>>2)) * ((signed int32)dig_P8));
var2 = A_SHRT(var2,13);
return p;
float Calculate_Pess()
return 0;
adc_P >>= 4;
var2 = var1 * var1 * ((float)dig_P6) / 32768.0;
var2 = var2 + var1 * ((float)dig_P5) * 2.0;
var2 = (var2/4.0)+(((float)dig_P4) * 65536.0);
var1 = (((float)dig_P3) * var1 * var1 / 524288.0 + ((float)dig_P2) * var1) / 524288.0;
var1 = (1.0 + var1 / 32768.0)*((float)dig_P1);
if (var1 == 0.0)
p = 1048576.0 - (float)adc_P;
var1 = ((float)dig_P9) * p * p / 2147483648.0;
var2 = p * ((float)dig_P8) / 32768.0;
p = p + (var1 + var2 + ((float)dig_P7)) / 16.0;
return p/100;
float BME280ReadHumidity(void) {
//readTemperature(); // must be done first to get
int32 adc_H = BME280Read16(0xFD);// BME280_REGISTER_HUMIDDATA
if (adc_H == 0x8000) // value in case humidity measurement was disabled
return 0;
signed int32 v_x1_u32r;
v_x1_u32r = (t_fine - ((signed int32)76800));
v_x1_u32r = (((((adc_H << 14) - (((int32)dig_H4) << 20) -
(((signed int32)dig_H5) * v_x1_u32r)) + ((signed int32)16384)) >> 15) *
(((((((v_x1_u32r * ((int32)dig_H6)) >> 10) *
(((v_x1_u32r * ((signed int32)dig_H3)) >> 11) + ((signed int32)32768))) >> 10) +
((signed int32)2097152)) * ((signed int32)dig_H2) + 8192) >> 14));
v_x1_u32r = (v_x1_u32r - (((((v_x1_u32r >> 15) * (v_x1_u32r >> 15)) >> 7)*((signed int32)dig_H1)) >> 4));
v_x1_u32r = (v_x1_u32r < 0) ? 0 : v_x1_u32r;
v_x1_u32r = (v_x1_u32r > 419430400) ? 419430400 : v_x1_u32r;
float h = (v_x1_u32r>>12);
return h / 1024.0;
// Read the uncompensated pressure value
In main.c
//#include <16f877A.h>
#include <16F887.h>
#fuses HS, NOLVP, NOWDT, NOPROTECT
#use delay (clock=8000000) //Use built-in function: delay_ms() & delay_us()
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7)
#include "LCD_TM.c" //use module function
#include "BME280.c"
#include<stdlib.h>
int8 a;
float temp, hu;
unsigned int32 press;
init_BME280();
BME280Begin();
delay_ms(200);
printf("\r\ndig_T1: =%LU dig_T2=%Ld dig_T3=%Ld", dig_T1, dig_T2, dig_T3);
printf("\r\nP1=%LU P2=%Ld P3=%Ld P4=%Ld P5=%Ld P6=%Ld P7=%Ld P8=%Ld P9=%Ld",dig_P1, dig_P2, dig_P3, dig_P4, dig_P5, dig_P6, dig_P7, dig_P8, dig_P9 );
printf("\r\nH1=%U H2=%LD H3=%U H4=%Lu H5=%Ld H6=%U", dig_H1, dig_H2, dig_H3, dig_H4, dig_H5, dig_H6);
while(true)
BurstRead();
temp = BME280ReadTemperature();
// press = BME280_compensate_P_int32();
hu = BME280ReadHumidity();
delay_ms(50);
press = Calculate_Pess();
delay_ms(50);
lcd_init();
lcd_gotoxy(1,1);
printf(lcd_putc, "%3.1f",hu);
lcd_gotoxy(8,1);
printf(lcd_putc, "%3.2f",temp);
lcd_gotoxy(1,2);
printf(lcd_putc, "%Ld",press);
printf("adc_H=%Ld",adc_H);
a = BME280ReadByte(0xF3);
// BME280WriteByte(0xF5,0x68); //011 (250ms tstandby) 0100 (filter coefficient =4) 0 (i2c)
lcd_gotoxy(15,1);
printf(lcd_putc, "%u",a);
lcd_gotoxy(10,2);
printf(lcd_putc, "%Lu",adc_P);
// printf("\r\nvar1_p=%Ld var2_p=%Ld var3_p=%Ld var4_p=%Ld var5_p=%Ld ", var1_p, var2_p, var3_p, var4_p, var5_p);
//printf("\r\nvar6_p=%Ld var7_p=%Ld var8_p=%Ld var9_p=%Ld", var6_p, var7_p, var8_p, var9_p);
// printf("\r\nvar11_p_p=%Ld var33_p=%Ld var44_p=%Ld t_fine=%Ld ", var11_p, var33_p, var44_p, t_fine);
// printf("\r\nvar444=%Ld var4444=%Ld", var444_p, var4444_p);
delay_ms(800);
viki2000
Posted: Tue Nov 07, 2017 8:35 am |
I have tested the above code for BME280 and in my case works with a small problem.
I need your advices to track down the problem.
In my setup I use PIC16F1829 with internal clock instead of the PIC16f877A.
I sent the data to a small LCD 2x8 using flex_lcd driver.
I force the hardware communication for I2C instead of software.
I am interested only on temperature and humidity.
My BME280 sensor has the address 76 (EC) instead of 77 (EE) – that I have tested with Arduino Uno, when I tested the sensor first time and works fine.
The data shown on LCD is meaningful info compared with Arduino Uno code and setup and it seems that the setup with PIC16F1829 and above code works.
What is my actual problem?
In the main subroutine, in the while(1) loop I must include “BME280Begin();”.
If the “BME280Begin();” is outside of the while(1), before of it, then it reads the sensor data only once at start-up and shows the same value all the time. But that is not normal, it is supposed to do the “BME280Begin();” only once before while(1) loop and not all the time.
Maybe I mixed up or forgot to change an address related with I2C or sensor, I do not know what is it.
Can you help to track down this problem?
Why in my case I have to do the “BME280Begin();” always?
What did I miss to change when I ported to code to PIC16F1829 and sensor address 76 instead of 77?
Here is the code that I have used:
Code: | //main code
//PIC16F1829 with BME280 address 76
#include <16F1829.h>
#use delay(internal=32000000)
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOCLKOUT //I/O function on OSC2
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES BORV19 //Brownout reset at 1.9V
#FUSES NOWDT
//#define BME280_SDA PIN_B4
//#define BME280_SCL PIN_B6
#use i2c(master, sda=PIN_B4, scl=PIN_B6, FORCE_HW)
#include <flex_lcd.c>
#include "BME280.c"
#include<stdlib.h>
int8 a;
float temp, hu;
init_BME280();
while(true)
BME280Begin();
delay_ms(200);
BurstRead();
delay_ms(50);
lcd_init();
lcd_gotoxy(1,1);
lcd_putc(" %");
lcd_gotoxy(1,2);
lcd_putc(" C");
delay_ms(800);
Code: | //************************************************
// 07/24/2017
// 08/17/12
#define BME280_ADDRESS 0xEC // I2C address of BME280 VDD
#include <math.h>
#include<stdint.h>
void init_BME280()
output_float(PIN_B4);
output_float(PIN_B6);
int1 BME280Begin()
return 0;
delay_ms(300);
return 1;
int8 BME280ReadID()
int8 data;
i2c_start();
i2c_write(0xEC); // 0X77 11101110X IS IC ADDRESS, 0X76 IS 1110 110
i2c_write(0xD0);
i2c_start();
i2c_write(0xED);
data=i2c_read(0);
i2c_stop();
delay_us(20);
return(data);
byte data;
i2c_start();
i2c_write(address);
i2c_start();
data=i2c_read(0);
i2c_stop();
return(data);
byte msb, lsb;
i2c_start();
i2c_write(address);
i2c_start();
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
return ( temp );
i2c_start();
i2c_write(address);
i2c_write(data);
i2c_stop();
byte msb, lsb;
return temp;
void BurstRead()
// int8 data[8];
i2c_start();
i2c_write(0xF7);
i2c_start();
i2c_stop();
i2c_start();
i2c_write(data);
i2c_start();
msb = i2c_read();
lsb = i2c_read();
i2c_stop(); //*/
return value;
delay_us(10);
return 0;
adc_T >>= 4;
return T/100;
return 0;
adc_P >>= 4;
unsigned int32 p;
//delay_us(100);
var5_p = var1;
if (var1 == 0)
if (p < 0x80000000)
return p;
return 0;
adc_P >>= 4;
if (var1 == 0.0)
return p/100;
return 0;
return h / 1024.0;
Code: | // flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
#define LCD_DB4 PIN_C4
#define LCD_DB5 PIN_C5
#define LCD_DB6 PIN_A4
#define LCD_DB7 PIN_A5
#define LCD_E PIN_C7
#define LCD_RS PIN_B7
//#define LCD_RW PIN_B6
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW 1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine. For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
//output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
if(address)
output_high(LCD_RS);
output_low(LCD_RS);
delay_cycles(1);
#ifdef USE_LCD_RW
//output_low(LCD_RW);
delay_cycles(1);
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 60 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_LCD_RW
delay_ms(5);
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
address = lcd_line_two;
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
lcd_send_byte(0,0x10);
default:
lcd_send_byte(1,c);
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif | [/code] |
Joined: 01 Jul 2010 Posts: 5960 Location: Greensville,Ontario
Posted: Tue Nov 07, 2017 8:58 am |
you should run the I2C Scanner program that PCM P posted in the code library. it will find your sensors true address. |
Posted: Tue Nov 07, 2017 9:04 am |
You need also to understand I2C addresses.....
The address occupies the top 7 bits of the byte sent to the sensor. The eighth bit is the read/write bit (1/0). A device that is at address 0x76, will need to be sent 0x77 to read, and 0x76 to write.... |
viki2000
Posted: Tue Nov 07, 2017 9:12 am |
@ temtronic
But I have used the I2C Scanner with Ardunio setup environment and I know the address is 0x76, besides that the code works except repeat begin initialization.
@ Ttelmah
In the library code for BME280 here above, similar as in Arduino library, the address 0x77 is transformed into 0xEE and the address 0x76 is transformed into 0xEC. The initial code is written like that. No where appears 0x77 or 0x76, but the corresponding 0xEE or 0xEC. I see no problem here. |
Posted: Tue Nov 07, 2017 10:05 am |
The Arduino library is using the 7 bit address. The top seven bits of the address byte. This was the old 'Texas' standard but is used by almost nobody else.
The CCS code uses the 8bit address. 7bit address *2. The code then adds the read/write bit as needed. This is how most manufacturers address their chips.
A device with an Arduino address of 0x77, will need 0xEE for the PIC code, and will physically be at addresses 0xEE and 0xEF.
You have 'waffled' far too much in your post which is why Temtronic and I both thought you were having trouble addressing the chip.
You post could be summarised as:
"Using this library (point to the thread, don't repost the whole library).
Chip works, but requires me to use BME280Begin() every time I want to send a reading. Without this I only get the first reading."
The reason you are having to send 'begin', is that you are programming the chip to 'forced mode', in which it goes back to sleep after a single reading. The Begin code as well as reprogramming all the registers triggers a single conversion.
You can just trigger a single conversion by writing the CTRL_MEAS register. Alternatively change the settings to use 'normal mode'. |
viki2000
Posted: Wed Nov 08, 2017 1:55 am |
I am sorry that I have 'waffled' far too much in my initial post and I created confusion.
I always thought that providing more info is always better than providing less, even if there is the risk that people do not read it because takes too much time.
Probably it would have been far better to summarize it as you did, but we do not all think and speak the same way.
Besides that, because I mentioned that I am able to read the BME280 parameters, that means automatically that I2C works fine and there is no problem with the address. That’s why your explanations with 7bit vs. 8bit make sense also for me because 0x76*2=0xEC and the following for read is 0xEC|0x01=0xED and these 2 addresses 0xEC and 0xED I have used in my code above.
I have posted the entire long code to see where I have done the modifications and maybe someone might say: hey, you forgot to change it there or there, at least this is what I had in mind to that moment. In top of that, for future users, is good to have full working code that is downloadable and applies without modification, just for a quick test without headaches. I thought a another PIC and another address for BME280 will diversify the options for other users, which is a good thing. Besides that many times when a question is asked, the people that are willing to help and answer ask almost always about the code used and in this case there are some places in the given code that must be modified in order to be adapted to the new PIC and new BME280. So I think is not a big deal that I posted the question in the way as I have done it.
Now, regarding your suggestions with “forced mode” and sleep and that I should change to “normal mode” or play with CTRL_MEAS register, they make logical sense to me at the first read, but I have some doubts when I think twice and here is why.
I suppose the initial provided code works fine.
If you look at the main subroutine, the “BME280Begin();” is called only once before the continuous “while(true)” and in that “while(true)” loop the reading of temperature and humidity is called regularly each approx. 1s and is then printed regularly.
It makes no sense to print regularly the temperature and humidity and other parameters, if it is not updated regularly with new data.
If what you say would be true, then it would be true also for initial code and here I have the doubts, because I suppose is working fine, of course not tested yet by me with PIC16F877A and BME280 address 0x77.
I think the “force mode” with sleeping is important, because consumes low current, which is good for portable application (nice explained here http://tinkerman.cat/low-power-weather-station-bme280-moteino/ ). I would like to maintain that low current state with sleeping and “forced trigger”.
But I also think the problem is somewhere else, why does not trigger a new reading. I have to look more into the code. Any other suggestions are appreciated. |
Posted: Wed Nov 08, 2017 2:13 am |
Big difference. Time.
The chip goes to sleep if it is not read for 250mSec. You delay 800mSec in your loop. The original code does not...
You have to simply trigger a reading. A read does not. |
