crazy fuses ?? in midrange 4.085??
PostPosted: Tue Sep 06, 2011 2:17 pm     Reply with quote
I have used ver 4.085 with the 16f/c family for years using internal osc and external crystals.
Also done a number of projects with 18f parts - but never had occasion to use an external crystal with the 18F parts
I've tried this with an 18f4520 and an 18f4620 - only changing to BORV43 for that part - with the same weird results. compare my fuse statement with what the compiler did. I would GREATLY prefer if anyone knew a work around - as the code that is generated otherwise for 18f parts has been satisfactory.
I am in NO Hurry to upgrade to a fresh version and its unknowns.
Is the following bizarre fuse compilation ME or the compiler ??
CCS PCH C Compiler, Version 4.085, 47322               06-Sep-11 15:54
               Filename: d:\abm\serdem5.lst
               ROM used: 172 bytes (1%)
                         Largest free fragment is 32596
               RAM used: 14 (1%) at main() level
                         14 (1%) worst case
               Stack:    1 locations
0000:  GOTO   0044
.................... #include <18f4520.h>
.................... //////// Standard Header file for the PIC18F4520 device ////////////////
.................... #device PIC18F4520
.................... #list
.................... #fuses HS,NOPROTECT,NOMCLR,NOWDT,NODEBUG,NOLVP,NOIESO,
.................... #fuses NOFCMEN,PUT,NOWRT,NOFCMEN,BROWNOUT,BORV42,   // borv43 in 4620
.................... #fuses CCP2C1,NOPBADEN,NOLPT1OSC,noxinst,
.................... #include <stdlib.h>
.................... #use fast_io(B)
.................... #use delay( clock=16588880,INTERNAL ) // clock changed to 80000
.................... #use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, ERRORS )
0030:  BTFSS  F9E.4
0032:  BRA    0030
0034:  MOVWF  FAD
0036:  GOTO   0082 (RETURN)
.................... #bit  T0IF    = 0xFF2.2  // flag in reg
.................... void InitHDW ( void ) {
....................      output_b (0);    //  - all INPUT
001E:  CLRF   F8A
....................      set_tris_b (0);
0020:  MOVLW  00
0022:  MOVWF  F93
....................      set_tris_c (128); // set bit 7 per datasheet for C7=INPUT
0024:  MOVLW  80
0026:  MOVWF  F94
....................      SETUP_TIMER_0(RTCC_8_BIT|RTCC_DIV_256);
0028:  MOVLW  C7
002A:  MOVWF  FD5
002C:  GOTO   0078 (RETURN)
.................... void zertime(void){
....................     t0if=0;  set_timer0(93);
003A:  BCF    FF2.2
003C:  CLRF   FD7
003E:  MOVLW  5D
0040:  MOVWF  FD6
0042:  RETLW  00
.................... void main() {
0044:  CLRF   FF8
0046:  BCF    FD0.7
0048:  CLRF   FEA
004A:  CLRF   FE9
004C:  MOVLW  60
004E:  MOVWF  FD3
0050:  MOVLW  40
0052:  MOVWF  F9B
0054:  MOVF   FD3,W
0056:  BCF    FB8.3
0058:  MOVLW  11
005A:  MOVWF  FAF
005C:  MOVLW  A6
005E:  MOVWF  FAC
0060:  MOVLW  90
0062:  MOVWF  FAB
0064:  MOVF   FC1,W
0066:  ANDLW  C0
0068:  IORLW  0F
006A:  MOVWF  FC1
006C:  MOVLW  07
006E:  MOVWF  FB4
0070:  CLRF   05
0072:  CLRF   06
0074:  CLRF   0B
....................     unsigned int8 i;
....................     InitHDW();
0076:  BRA    001E
....................     printf ("*Hello*\r");  // quick check output baud
0078:  CLRF   0D
007A:  MOVF   0D,W
007C:  RCALL  0004
007E:  INCF   0D,F
0080:  BRA    0030
0082:  MOVLW  08
0084:  SUBWF  0D,W
0086:  BNZ   007A
....................     while (1) {           // now get AND send at same time
....................           for (i=0; i<255; i++){
0088:  CLRF   0C
008A:  INCFSZ 0C,W
008C:  BRA    0090
008E:  BRA    00A8
....................               output_high(pin_b0);
0090:  BSF    F8A.0
....................               zertime();
0092:  RCALL  003A
....................               while (!t0if){};
0094:  BTFSC  FF2.2
0096:  BRA    009A
0098:  BRA    0094
....................               output_low(pin_b0);
009A:  BCF    F8A.0
009C:  RCALL  003A
009E:  BTFSC  FF2.2
00A0:  BRA    00A4
00A2:  BRA    009E
00A4:  INCF   0C,F
00A6:  BRA    008A
....................     }  //         END : while  1
00A8:  BRA    0088
00AA:  SLEEP
Configuration Fuses:
   Word  1: 0800   NOIESO NOFCMEN INTRC_IO
   Word  2: 1E0E   BROWNOUT NOWDT BORV42 PUT WDT32768
   Word  3: 0100   NOPBADEN CCP2C1 NOLPT1OSC NOMCLR RESERVED
   Word  4: 0081   STVREN NODEBUG NOLVP NOXINST RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
Is there a work around or did I do something that caused this ??
PostPosted: Tue Sep 06, 2011 2:31 pm     Reply with quote
You.
You are specifying HS (external crystal), then overriding this with your clock statement (,INTERNAL.....)
