smanzer
Joined: 14 Sep 2009 Posts: 24 Location: Ontario, Canada
| Pointer to function problem |
Posted: Sat Jul 17, 2010 6:21 am |
Good morning,
I have found an interesting challenge when trying to run functions when using a structure containing a function pointer. I have read everything I can about work arounds on this forum and although the posts have helped I am still having trouble.
The pic is a 18F8722, compiler is 4.093.
I have many include files as part of a home automation system. The program is becoming quite large with ROM=73% and RAM 35-44%
When I call the menu routine to save the function pointer to be called I get a pointer value that is beyond $FFFF for example $0104B2. Looking at the .lst code shows that that is where the function resides. I modified the code as suggested by PCM_Programmer to make it a 16 bit variable, but this is a 17 bit number. So, I changed it to a 32 bit number.
The function never runs. It is only the functions that have a 17bit pointer that do not execute. Here is how the function is called when using a pointer to the function that is stored in a structure:
typedef void (* _void_fptr)(void); // note functions are passed and return void
typedef volatile struct MyMenuItem{
struct MyMenuItem *NextItem;
struct MyMenuItem *PrevItem;
struct MyMenuItem *SubMenu;
char Text[21];
int32 FunctionPtr;
} MenuItem;
temp = m->FunctionPtr; // temp is _void_fptr FunctionPtr is int32
(*temp)();// execute the code for the menu item
I assume the problem is that the functions that do not run are in a different memory segment. Any chance someone has a work around for accessing functions in another memory segment?
Thanks in advance,
Steven _________________ "I am always doing that which I can not do, in order that I may learn how to do it."
- Pablo Picasso |
Posted: Sat Jul 17, 2010 10:58 am |
My first thought is to use #org to put anything that involves function
pointers into the first 64KB of Flash. |
smanzer
Posted: Sun Jul 18, 2010 7:35 am |
Thanks PCM_Programmer, that should work! I have a variable that I use to turn on/off debugging info to the pc terminal. When I turned it off, the program size dropped so the offending functions were in the first 64K and it all worked as expected.
I have never used #org, would this be correct for an 18F8722:
#org 0x0000, 0xFFFF
Looking at the data sheet, it looks like On-Chip Program memory goes from 0x00000 to 0x1FFFF, there are Reset Vectors and Interrupt vectors from 0x0000 to 0x0018, do they have to be excluded like:
#org 0x0018, 0xFFFF
Thanks for helping again PCM_Programmer!!
- Pablo Picasso |
